Sorry if this is the wrong section
I have a set of bbs VZ on my Pirelli..... the offset is 44 on a 8” wide rim . The new Wheels were supplied with new bolts . The new bolts are the same length as the standard bolts .
Is this ok ?
As in my mind I have 7mm less bolt holding my wheels on !
Standard offset on my Pirelli ( assume it’s the same as the edition 30 ) is et51 on a 7.5” rim .
I have 7.5 turns on the bolt until tight on the VZ Wheels ... should I be getting longer bolts to be safe ?
Thanks for any help
