Author Topic: Footwell Lights Gone Weird.  (Read 1006 times)
Offline Hendry
« on: January 02, 2018, 08:21:33 pm »
Hi guys, got a strange issue, my front footwell lights used to work normally, then I had them coded with VCDS to be on permanently when the dash lighting and exterior headlights are on, and they worked fine for months after the coding, however now my footwell lights only work for the first 5 seconds after switching ignition on now, they no longer work either how they were coded to work as in be on permanently nor do they work as they originally did since new.
Im a bit puzzled!
Offline doylebros
Re: Footwell Lights Gone Weird.
« Reply #1 on: January 02, 2018, 09:12:24 pm »
If you've not changed the footwell bulbs, I would get the coding rechecked.
