Author Topic: MDI retrofit iPhone issue  (Read 1606 times)
Offline Joshy
« on: January 05, 2018, 06:20:12 pm »
Evening all,
Earlier today i did a test fit of my MDI armrest unit, everything seemed to go well at first. My RNS 510 showed the "MDI" option when clicking the media button, but when i tried to plug my phone into it, i got the error message
"MEADIA IN: Device without function"
For connectors, i'm using a MDI > USB and the plugging the standard apple lighting USB cable into that
The phone charges, so i know something is happening but unsure why I'm getting the message mentioned above.
Would using a MDI > Lighting cable be a better option?
Offline Pashka
Re: MDI retrofit iPhone issue
« Reply #1 on: January 06, 2018, 10:12:25 am »
You need MDI lighting adapter, will not work via usb>cable.  :happy2:
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Raj2212
  • -Given: 75
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115142.0.html
« Reply #2 on: January 06, 2018, 10:31:53 am »
Hi. @Joshy  . When I installed an rcd510 to my sisters Mk6 tdi I bought ona these cables which worked bang on. Recommend getting a longer cable.
Also I remember that 1 song needs to be on the actual iPhones music for it to pick up the phone. Weird but this was the only way to play music from YouTube Tubidy etc.
Hope this helps
Link https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F231559881099
Offline Joshy
« Reply #3 on: January 06, 2018, 02:20:13 pm »
Ah I see! I guess the MDI > USB cable only transmits the power and not data. Guess I'll buy myself one of the MDI lighting adapters then, just a shame they are expensive!
Hope this helps
Thank you Raj, I'll have a look at that cable. Useful for my phone as i have the Aux port still, but the missus' phone only has the lightning port. Hopefully a MDI > lightning cable as Pashka suggested will be the one  :happy2:
