Author Topic: Parts needed for servicing  (Read 2160 times)
Offline Eves
  • -Given: 45
« on: January 08, 2018, 12:03:26 pm »
My vehicle needs a service
Book points to a major service - what parts would be needed as want to do it myself.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Parts needed for servicing
« Reply #1 on: January 08, 2018, 02:40:56 pm »
Oil 5W-30 or 5W-40
Oil Filter
Air Filter
Pollen Filter
Spark Plugs
Check all tyres
Check all suspension components
If you want or can do:
Check cam follower
Check DV
Replace Fuel filter
Possibly replace DSG gearbox fluid
Check timing belt and water pump replacement period i.e. mileage or time since last change.
« Reply #2 on: January 08, 2018, 02:48:28 pm »
Cam follower and Fuel filter for sure.
Brake & clutch (if manual) fluid flush as well.  Should be done every 2 years.
Clean and grease the bonnet latch.
Grease all the hinges.
VW also do a full inspection on the lift, which most DIYers can't do.
Offline Eves
  • -Given: 45
« Reply #3 on: January 08, 2018, 07:27:15 pm »
Cheers chaps
