Author Topic: Troubleshooting a missfire (hiccup)  (Read 7876 times)
Offline neg
  • gone old skool
« on: December 29, 2008, 11:26:12 pm »
Ideally to help find the fault you will need VCDS (vagcom).
Try and get the engine management light to lite on the dash so a fault is logged to the ECU.
Read the fault - normally a 'random multiple missfire detected' and then it will list the cylinder at fault
1st step - coilpack
swap the cylinder from the detected faulty cylinder to another, e.g. cylinder 1 detectedm swap coilpacks 1 and 4.  Cylinders are from left to right looking at the engine with the bonnet open - (washer fluid) 1-2-3-4 (battery)
Clear the fault and test the car.
If you succeed in another engine management light...
check error code again - see if the cylinder detected this time is where you moved the suspect coilpack too - if this is so swap the coilpacks back to their original positions and replace the faulty one, if not   ->
2nd Step - spark plugs
Replace all 4 spark plugs with VW recommended parts.
Clear fault and test again.
This will normally fix a well known random/multiple missfire.
VW Latest coilpack is revision D - approx £30 + vat each
VW Spark plugs - approx - £9.50 + vat each
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Troubleshooting a missfire (hiccup)
« Reply #1 on: December 30, 2008, 10:01:00 am »
Good write-up Neg  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #2 on: December 30, 2008, 10:44:15 am »
Nice one Neg , I thought rev F was the latest coil packs, is that different between us and the USA  ?
Red ED35 5dr DSG
BLOG | BUILD
Offline neg
  • gone old skool
« Reply #3 on: December 31, 2008, 11:11:42 am »
I think it was D, I'll double check...
« Reply #4 on: January 01, 2009, 08:34:19 pm »
Useful and very clear guide, neg :happy2:
