Author Topic: Damper to match Eibach springs  (Read 5444 times)
Offline delob
« on: January 09, 2018, 06:54:11 pm »
I am currently running 20mm Eibach with oem dampers and the time has come for some new dampers. Not looking to go the coilover route so what options do I have? I could always just go oem again but I find the ride a bit harsh and was thinking there might be an alternative. Any suggestions would be appreciated. Thanks
Graphite Blue MK5 GTI
Offline Bodyboarder81
  • -Given: 35
Re: Damper to match Eibach springs
« Reply #1 on: January 09, 2018, 06:59:42 pm »
Bilstein b6/b8 :)
« Reply #2 on: January 10, 2018, 11:25:46 am »
B6 will be a better match to -20mm springs, and so long as they are the softer MK6 version, the ride should be OK.
The ride could be harsh because the OEM dampers are worn out.   New ones from the dealer aren't expensive and will be a big improvement on old knackered ones.
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #3 on: January 10, 2018, 12:37:59 pm »
I'm getting my Eibach springs with Bilstein B4 Sport dampers fitted on Friday - I'll let you know how it goes.
The B4 Sport are pretty much like for like replacements for the originals.
Offline Shoy1980
« Reply #4 on: January 10, 2018, 12:52:00 pm »
Won't the lowered springs just eat away the B4's like they eat away OEM?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: January 10, 2018, 01:51:21 pm »
I find my Koni Sport softer than my friend's B8 with the same springs, H&R -30 mm. The Koni work well with OEM and shorter springs. They're also adjustable while the B8 aren't.
Offline shail
« Reply #6 on: January 10, 2018, 04:47:06 pm »
I think it probably will shorten the life of the shocks, but by how much I don't know.   The Eibach springs I have don't lower the car massively, so hopefully the shocks will hold up quite a while.  I have the B4 'sport' rather than the standard B4.  I once read that the 'sport' versions are stiffer & shorter, so hopefully will be well matched to the springs.
I think if I drove the car like loon all the time, I'd have gone for a different set up.  As it happens, I don't chuck it about too much, but want a nice ride - guess I'll find out Friday!
« Last Edit: January 10, 2018, 04:53:53 pm by shail »
Offline Damian @ DPM
  • DPM Performance
« Reply #7 on: January 11, 2018, 02:07:08 pm »
Bilstein B8 gets my vote, you'd basically have the B12 kit.
Damian @ DPM Performance
Advertising removed... (for the time being)
Offline OEM+ DUB
« Reply #8 on: January 11, 2018, 03:50:59 pm »
Fully agree with the comment above - I fitted B8's to mine (with VWR springs) and haven't looked back to the wallowing, imprecise and past its best standard spring/damper set up which had degraded over the previous 8 years of ownership.  Fitted this combo in June 2016 and have covered 10k on this setup so this isn't a 'rose-tinted-just-fitted' perspective.
Hope this helps.
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #9 on: January 11, 2018, 11:45:51 pm »
B8's for lowering springs. Have them with different springs now but had them initially with sportlines; being my first set of springs.
  • -Given: 35
« Reply #10 on: January 12, 2018, 10:03:29 am »
Interested to know  what springs you are using now with the b8’s ? I have the b8 and sportline eibach’s but would love for it to sit a tad lower purely for looks
« Reply #11 on: January 12, 2018, 03:57:13 pm »
Sportlines are plenty low enough!  Coilovers for you my friend  :happy2:
  • -Given: 35
« Reply #12 on: January 12, 2018, 04:24:53 pm »
Well I think they are sportline ...... I think the previous owner thought he had the b12 Pro kit ... but to my knowledge ( stand to be corrected ) the pro springs were always black and the sportline red .. I have red
« Reply #13 on: January 12, 2018, 05:37:03 pm »
Ya, Pro is -20ishmm. Sportline is -30 odd mm.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #14 on: January 13, 2018, 05:57:23 pm »
I have H&R Street Pref. coil-over springs and adj. perches in the rear and H&R SS springs in front. H&R SS springs aren't available in the UK I am told. All with B8 dampers. I believe Sportlines are about the lowest springs you can get there without going coil-overs.
« Last Edit: January 13, 2018, 05:59:02 pm by ROH ECHT »
