Yep I've replaced them. They do squidge down a fair bit after 100+ k miles.
There is a plastic clip that attaches them to the trailing arm, which usually breaks when you try to remove it, but that clip appears to be for factory transportation/assembly use only as it's not listed as a separate part on the system.
I fitted the spring mounts without said clip and had no problems.
