November 18, 2024, 12:38:20 am
All Things Mk5
Mk5 General Area
Best DV - Dump Value
Topic: Best DV - Dump Value (Read 1621 times)
Assad
Just Arrived
-Given: 0
-Receive: 0
January 12, 2018, 10:58:44 am »
Fancy installing a dump value on my ED30 which is running a stage 2+ whats the best onces out there dont want something that sounds chavy...
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: Best DV - Dump Value
Reply #1 on:
January 12, 2018, 11:57:08 am »
OEM is all you need, or GFB DV+.
MIJ_JAGGER
Won't Shut up.
-Given: 103
-Receive: 78
Reply #2 on:
January 12, 2018, 12:21:26 pm »
I found a forge spacer bov thingy in the boot when I got the motor, stuck it on then took it off sharpish, very loud psshhhhhh, no thanks
Assad
Just Arrived
-Given: 0
-Receive: 0
Reply #3 on:
January 12, 2018, 12:21:43 pm »
Do the golf ed30 come with BOV standard?
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #4 on:
January 12, 2018, 01:18:56 pm »
They come as standard with a recirculation valve, which is all you need. Makes plenty of noise with an open cone style intake, especially once remapped.
Do not fit any kind of vent to atmosphere type valve
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
Shoduchi
-Given: 220
-Receive: 429
My Ride:
Reply #5 on:
January 12, 2018, 02:15:40 pm »
GFB DV+. I do need to check how mine is doing after 2 years of use. No issues with it so far.
Silver Reflex Mk5 Golf GT Sport
.:R-Line
1.9 TDI 105@171PS 5 Doors
Candy White Mk5 Golf GTI Edition 30 DSG 230@409PS 3 Doors
Bodyboarder81
Always Involved
-Given: 35
-Receive: 4
Reply #6 on:
January 12, 2018, 03:58:38 pm »
What’s the Symptoms of a faulty one? What do I check ?
MIJ_JAGGER
Won't Shut up.
-Given: 103
-Receive: 78
Reply #7 on:
January 12, 2018, 04:56:47 pm »
Best thing to do is just check the dv itself for tears in the rubber diaphragm.
Easy enough to remove, much easier on an eddy
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #8 on:
January 12, 2018, 05:40:44 pm »
Lack of top end power, spikey inconsistent boost delivery and under boost fault codes.
All Things Mk5
Mk5 General Area
