Author Topic: Dv noise help  (Read 3097 times)
Offline Ash_89
Dv noise help
« on: January 12, 2018, 05:59:53 pm »
I’ve changed my thermostat today and thought I’d replace the dv for a rev g
Once taking the valve off I stupidly didn’t check if it had been replaced before , and what do you know it had  !
I’ve re fitted the old valve but now get a dv noise when changing gear that wasn’t there before does anyone know what usually causes that noise (fast and furious dv noise )
  • -Receive: 692
Re: Dv noise help
« Reply #1 on: January 12, 2018, 06:18:25 pm »
Assume you mean a pssshhht noise Buses make when you back off the gas?
Have you got an aftermarket intake?  You don't hear that noise with the standard intake.
But a psssshht is normal, it means the DV is doing it's job.
Offline Ash_89
Re: Dv noise help
« Reply #2 on: January 12, 2018, 06:33:22 pm »
It’s standard mate yeah like a old skool Baileys dump valve haha standard air box too
I’m thinking I couldn’t of tightened the bolts holding the dv on properly
Offline Ash_89
Re: Dv noise help
« Reply #3 on: January 12, 2018, 07:46:35 pm »
One thing I did noice was oil on the plug when I removed it so I sprayed some contact cleaner in there
I’m changing the oil tommorow so il have another look then
  • -Receive: 692
Re: Dv noise help
« Reply #4 on: January 12, 2018, 10:10:38 pm »
Oil in the Diverter valve connector?   You've got oil wicking up the wires from somewhere. Have a look at the plastic corrugated PCV hose.  They are known to split and piss oil vapours out under boost.
You shouldn't hear the dumping with the standard intake, so something not quite right there.
Offline Ash_89
Re: Dv noise help
« Reply #5 on: January 13, 2018, 03:30:54 pm »
All sorted I put the dv on the wrong way there’s a locating lug on the dv
Oh well it’s all good now haha thanks for the reply’s thou mate
