November 17, 2024, 10:38:43 am
All Things Mk5
Mk5 General Area
Random exhaust pop ?
Topic: Random exhaust pop ? (Read 1642 times)
Bodyboarder81
Always Involved
-Given: 35
-Receive: 4
January 13, 2018, 12:25:36 pm »
Hi all ,
I’m getting a random exhaust pop every now and then . Seems to be once the cars up to temp and just done it once on a 30 min drive . I’m running a full milltek turbo back non res system . The plugs were done 3k ago .... coil pack going? Drives fine and no lights ect
What’s people’s thoughts ?
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: Random exhaust pop ?
Reply #1 on:
January 13, 2018, 06:36:39 pm »
Misfire. If not spark related, probably a lazy injector.
Bodyboarder81
Always Involved
-Given: 35
-Receive: 4
Reply #2 on:
January 13, 2018, 06:51:42 pm »
Quote from: Pudding on January 13, 2018, 06:36:39 pm
Would that put a code on the ecu telling me what cylinder it is ?
I did possible suspect a injector also .... already bought some injector cleaner to run through but not expecting it to do much
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #3 on:
January 13, 2018, 06:54:09 pm »
Only if it's a persistent misfire. Occasional popping won't be fault coded. Mine started doing that a couple of years ago and then eventually it got to the point where the ECU flagged a misfire on cylinder 3. Injector was on it's way out.
Bodyboarder81
Always Involved
-Given: 35
-Receive: 4
Reply #4 on:
January 13, 2018, 06:57:26 pm »
I’ll just keep an ear out then .... really is like once every 30-40 miles at the moment. It’s due a service in March so I’ll ask Jkm to look at it when they do the service , fit Loba, stage2+ it
GTi-Tecnix
Always Involved
-Given: 13
-Receive: 1
Reply #5 on:
January 16, 2018, 08:05:03 pm »
Yes agree here - an injector misfire. Mine did the same at idle after parking up for 10mins.
Rapid Acceleration on a Slippery surface
Sounds like a MK5 GTI 💥👊🏽💯
All Things Mk5
Mk5 General Area
