Author Topic: Cruise control not working (mystery)  (Read 7911 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Cruise control not working (mystery)
« Reply #15 on: January 16, 2018, 09:02:43 am »
If you've got a standard GTI steering wheel shouldn't the coding value for the wheel be (1) not (0).
was jut going to point that out as well. lol  Try changing coding to 0001042
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #16 on: January 18, 2018, 09:54:38 pm »
Wasn't there something about logging in witha code 41*** and then set the CC  :thinking: I'm sure @RetroRaz helped me out here
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« Reply #17 on: January 20, 2018, 04:24:31 pm »
Still haven't solved this guys  :sad1:
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #18 on: January 20, 2018, 04:35:50 pm »
WHen the green light is on you need to be at a constant speed with foot on the accelerator to enable cruise which might be the issue of light comes on
Offline jhook661
  • -Receive: 20
« Reply #19 on: January 22, 2018, 07:01:47 pm »
The green light doesn't come on/engage that's the problem
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #20 on: January 22, 2018, 11:45:03 pm »
Sounds like a dodgy stalk  :thinking:
Offline The Red Warrior
« Reply #21 on: January 23, 2018, 08:22:16 am »
I'm guessing you have the wrong revision cruise control stalk.
You say in you original post that you have added the wire. I assume you mean the wire into the engine bay.
You also say in your original post that you have the correct steering wheel control module and slip ring. Are these original or have you retrofitted a mk6 wheel and the associated parts?
If original, for your year car, your cruise control stalk should have 8 pins. If you've retrofitted to mk6 wheel along with a CH revision steering wheel control module then your cruise control stalk should be a 'G' revision with only 7 pins. Revision 'G' and older revision stalks both have 8 wires but on the revision 'G' the 2 yellow wires join together and go to only 1 pin.
Even if you have bought a revision ’G', check to make sure both yellow wires are joined together and only going to the 1 pin.
When I retrofitted my mk6 wheel the cruise control stalk I bought was supposed to be a revision 'G' but the wires were the same as my old stalk. I was having the same problems as you.
I actually joined the 2 yellow wires in my original stalk (from memory it's the outside pin that you leave vacant) and reinstalled that. Problem solved.
Hope that is your issue too.
Offline jhook661
  • -Receive: 20
« Reply #22 on: January 23, 2018, 06:54:54 pm »
@The Red Warrior  thanks for that
I've got a rev G cruise stalk
Rev F steering wheel control module (midline)
Rev C slip ring
Is there any links to change the cables around etc ..
« Reply #23 on: January 24, 2018, 06:20:39 am »
Rev C slip ring
@jhook661
A search turned up my own thread on Ross tech. Here's the link:
http://forums.ross-tech.com/showthread.php?7272-Mk6-golf-steering-wheel-into-mk5-issues
In that thread you'll see a photo that shows the two yellow wires modified to be joined together.
My memory is quite what I thought as it shows there are 10 wires not 8 as I stated earlier.
The yellow wires in revision A and B stalks go to pins 5 and 10.
In revision G you have both wires going to pin 10 and pin 5 is left vacant.
So basically you have to pull out the yellow wire in pin 5, (or just cut it near the end) cut off some of the insulation on the yellow wire going to pin 10 and then solder the end onto the exposed section (or twist and tape if you want to easily try it first).
I found some other links with photos but they weren't showing due to photobucket's antics. I realise there are work arounds to show them but I've never used them. Maybe you have.
« Last Edit: January 24, 2018, 06:23:24 am by The Red Warrior »
Offline jhook661
  • -Receive: 20
« Reply #24 on: January 24, 2018, 05:30:17 pm »
@The Red Warrior any ideas ? 5&6 are vacant but that's the same as the one in the photo now I'm confused ...
« Last Edit: January 24, 2018, 05:35:18 pm by jhook661 »
« Reply #25 on: January 24, 2018, 08:40:00 pm »
I suspect you need wires in pins 5 & 10 as you say you are using an F revision steering wheel control module.
Of course this makes things more difficult as you will have to attach a new plug to the correct wire after uncoupling it from the existing plug that it’s attached to.
Offline jhook661
  • -Receive: 20
« Reply #26 on: January 24, 2018, 10:21:14 pm »
Has yours got a cable In no.5 ? As you said on your previous post no.5 is vacant?
« Reply #27 on: January 25, 2018, 03:04:39 am »
Not anymore.
It did have, but I removed it to splice into the other yellow wire going into pin 10 when doing my steering wheel conversion.
I’ve even got a spare cruise control stalk with wires going into pins 5 & 10 that you can have for free. It’s brand new. I never used it, as I chose to keep my original one and join the wires.
Only problem is you would have to pay for postage and I’m in New Zealand.
I’m sure you’ll be able to get a plug locally from a wrecker or just the pin from eBay.
