Author Topic: Removal of airbag warning light??  (Read 2294 times)
Offline Mickymurf
« on: January 15, 2018, 12:11:08 pm »
Hi my mk5 gti airbag warning light is currently on, is it possible to get it turned off via Vagcom or the likes? And how much would an auto electrician usually charge for such a job?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Removal of airbag warning light??
« Reply #1 on: January 15, 2018, 12:22:58 pm »
Look in the VCDS owners register, find someone near you, give them a few pound for the hassle.
Dealer will charge around £50
Takes two seconds to turn off via VCDS (formerly known as VAGCOM)
« Reply #2 on: January 15, 2018, 02:04:17 pm »
Dealer is 1 hour minimum charge for that now, so £100+.
Try disconnecting and reconnecting the yellow plugs under the seats if you can't get a scan locally.  The passenger warning light itself can be a pain if you've messing around installing new radios etc recently.
Colinspence
« Reply #3 on: January 15, 2018, 09:49:10 pm »
Check this item number on eBay. 172979108866
Iv got one and turns off air bag lights. £27 too so cheap cheap
Offline Mickymurf
« Reply #4 on: January 17, 2018, 01:19:19 pm »
Thanks for that, ordered one hopefully this will sort it
« Reply #5 on: January 17, 2018, 02:28:29 pm »
You can't just simply turn off the light.  If there is a fault, the light will keep coming back on.
Offline Pesky jones
« Reply #6 on: January 17, 2018, 03:26:42 pm »
How luke?
Pretty sure you can't. Used to be able to on older systems (mk4 etc) with VAGCOM
You need to build a resistor for each airbag to keep the light off.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #7 on: January 17, 2018, 03:32:54 pm »
How luke?
Just a reset of fault codes turns it off.
OP never said it was a continuous error, I assumed he just unplugged it accidentally
« Reply #8 on: January 17, 2018, 04:01:34 pm »
How luke?
If you mean bypassing the Airbag light, that is an MOT fail.   Just like the ABS, the testers want to see the light come on, then go off.   No light at all will be an instant fail.
Offline Pesky jones
« Reply #9 on: January 17, 2018, 04:33:18 pm »
When I looked into it last year the rules on SRS had changed recently. Looking now, it appears they have changed again, or issued new guidance;
https://mattersoftesting.blog.gov.uk/common-mistakes-made-by-mot-testers/
"When testing SRS MIL (Malfunction Indicator Light) lamps we are only looking to see if the lamp indicates if there is a fault with the system. If no lamp is present or it doesn’t illuminate then it can’t indicate a system fault, so it can’t be failed. Some vehicles may also incorporate warning messages on dash board displays; these are in addition to any MIL lamps and should not be used as a reason for rejection"
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: January 17, 2018, 11:43:30 pm »
£145 at my local vw  :stupid: prices
« Reply #11 on: January 18, 2018, 09:29:24 am »
Blimey, that is very surprising.  I would have thought safety systems would be under more scrutiny than that.
Offline Mickymurf
« Reply #12 on: January 18, 2018, 03:52:21 pm »
Thanks the £28 quid eBay obd reader worked!
Offline Pesky jones
« Reply #13 on: January 18, 2018, 03:57:47 pm »
Ah noo, a 2£ one would have worked as well! Thats all you need to clear codes.
