Author Topic: Mk5 Gti DSG shift boot replacement  (Read 3599 times)
Offline MattMK5
« on: January 24, 2018, 08:21:05 pm »
Hi everyone
Has anyone replaced the shift boot on a mk5 gti DSG? If so is their a how to guide ?
I have a new boot to replace my current one but looking for some help as to how the boot comes away from the actual shift knob
Thanks In Advance
Matt
2006 Reflex Silver Mk5 gti DSG
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: Mk5 Gti DSG shift boot replacement
« Reply #1 on: January 24, 2018, 11:55:13 pm »
I did have a quick look when I had the shifter off a while back and it looked like the boot is attached permanently and only way off is to either cut or break the plastic thing holding it on.
Will have a closer look as I’m planning to change mine too.
Offline MattMK5
« Reply #2 on: January 25, 2018, 10:16:43 am »
I'd be interested to have another person's view on it before i go attacking mine
Matt
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #3 on: January 25, 2018, 10:19:11 am »
I’ll update once I’ve had a butchers
Vice versa please if you figure it out
Offline v4rley
  • -Receive: 104
« Reply #4 on: January 25, 2018, 12:58:28 pm »
I had a look at this back in the day   :innocent: I didn’t have much luck here is a photo of what your looking at:
The material is pinched between the black and chrome, I had one made out of the ‘tartan’ seat material but this proved to thick for the gap and was glued to the black bit instead it didn’t work well so I gave up.
Offline v4rley
  • -Receive: 104
« Reply #5 on: January 25, 2018, 01:04:30 pm »
Haha here’s my post from years ago.
Had another attempted today at removing the gaiter, with some 'success'. I used a hair dryer to heat up around the top of the gaiter in case glue was holding it on. I ended up going for it and just pulling the gaiter down to release it from the top part. It had a fair amount of visible glue around the top of the gaiter.
I then set about trying to establish how to have to release the rectangular piece of plastic originally beneath the gaiter. It soon became apparent that it is not possible to remove this piece. Is you look on the photo below, I have circled what looks like retaining pegs to keep it on its position and would initially appear that one press in the would release it. But they don't, and if somehow they did it still wouldn't clear the bottom parts I marked with the arrows. So I assume it was put together bottom to top  :sad1:
The method I'm gonna try is to push the new gaiter between the plastic rectangle and metal collar and apply plenty of glue like found on the gaiter!
Sure this will be of some assistants for future reference  :happy2:
Offline MattMK5
« Reply #6 on: January 25, 2018, 05:45:53 pm »
V4rley
This this work out ok for you in the end ?
Offline v4rley
  • -Receive: 104
« Reply #7 on: January 25, 2018, 06:39:24 pm »
@MattMK5 no :signLOL:
It just didn’t work but I think that was mainly because my custom made one was to thick, so not only did it have to much play when changing through the positions it also would stick / tuck to the knob. So I got a mk6 instead.
Offline MattMK5
« Reply #8 on: January 25, 2018, 06:50:37 pm »
:grin: :congrats: brilliant
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #9 on: January 25, 2018, 06:57:46 pm »
I’ve actually got a mk6 on mine too that I’m looking to change the gaiter on, hopefully it’s easier on that
