Author Topic: COOLING FAN PROBLEM , OR NOT ? Help Please !!!  (Read 1486 times)
Offline clemo
« on: January 27, 2018, 07:33:06 pm »
Hi all,
I have a problem with my cooling fans ,    the other day I went out and found my Battery flat ,  I changed it only to find as soon as I put a new one on the cooling fans come on full and stay on , this is what has flattened the Battery .  any ideas please . ??
as soon as I put the ignition on the fans stop ....   I lock the car and walk away a few minutes later they come on full and stay on
After reading on here all night , some say Module in Master fan , some say Relay or  one of two sensors ,  Ross tech say as I have multiple  0010 Malfunctions it could be Battery / alternator /cables  etc .
CAN someone please advise
Regards
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0H23NA8IH
   Coding: 040300031C070160
   Shop #: WSC 00014 210 88554
   VCID: 377DCD5746B85FA6659-8062
8 Faults Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 188799 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:36:36
             Freeze Frame:
                    RPM: 847 /min
                    Load: 22.0 %
                    Speed: 0.0 km/h
                    Temperature: 78.0∞C
                    Temperature: 26.0∞C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 004 - Circuit Open - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 197965 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 253 /min
                    Load: 76.4 %
                    Speed: 0.0 km/h
                    Temperature: 39.0∞C
                    Temperature: 32.0∞C
                    Voltage: 11.176 V
005425 - Camshaft Timing Adjustment
               P1531 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 197965 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 253 /min
                    Load: 76.4 %
                    Speed: 0.0 km/h
                    Temperature: 39.0∞C
                    Temperature: 32.0∞C
                    Voltage: 11.176 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 197965 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:50:44
             Freeze Frame:
                    RPM: 263 /min
                    Load: 76.4 %
                    Speed: 0.0 km/h
                    Temperature: 39.0∞C
                    Temperature: 32.0∞C
                    Voltage: 10.922 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0∞C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 001 - Signal too High - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 39.0∞C
                    Temperature: 33.0∞C
                    Voltage: 11.938 V
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 197965 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:34
             Freeze Frame:
                    RPM: 253 /min
                    Load: 76.4 %
                    Speed: 0.0 km/h
                    Temperature: 39.0∞C
                    Temperature: 32.0∞C
                    Voltage: 11.303 V
000579 - Solenoid Valve  for Boost Pressure Control (N75)
               P0243 - 004 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 197965 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:34
             Freeze Frame:
                    RPM: 253 /min
                    Load: 76.4 %
                    Speed: 0.0 km/h
                    Temperature: 39.0∞C
                    Temperature: 32.0∞C
                    Voltage: 11.303 V
Readiness: 0110 0001
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 050 H    HW: 02E 927 770 AE
   Component: GSG DSG         082 1401
   Revision: 04708020    Serial number: 00000802130080
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 173D2DD726787FA6459-8042
No fault code found.
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6DD12F3F746425764F5-8038
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000008140883
   Coding: E58D8F2700041500471400001400000000187F075C000100000000000000
   Shop #: WSC 12345 785 00200
   VCID: 71E9334F685CC1966BD-8024
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 050308 021  0501
   Coding: 00038805
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     140308 054  0402
   Coding: 00209069
   Shop #: WSC 12345
3 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 70
                    Mileage: 197956 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 6.95 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 70
                    Mileage: 197956 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 5.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01309 - Power Steering Control Module (J500)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 197965 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1VTCZS
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D71DF7F648475F6BF5-8068
   Subsystem 1 - Serial number: 6332MSME2E331971B
   Subsystem 2 - Serial number: 6342MSME394148337
   Subsystem 3 - Serial number: 6352QSME58392373H
   Subsystem 4 - Serial number: 6362QSME56313E69P
1 Fault Found:
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0012122
   VCID: 78FF0E6B0B2690DEAC3-802D
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
2 Faults Found:
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H23NA8IH
   Coding: 0003403
   Shop #: WSC 01219 002 1048576
   VCID: F1E9B34FE85C4196EBD-80A4
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 70
                    Mileage: 197956 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:12:17
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 70
                    Mileage: 197956 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:13:14
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 72
                    Mileage: 197965 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:02:12
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 060308F2001100
   Coding: ED807F064006020003
   VCID: 306FF64BA3D6889E243-8065
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 72
                    Mileage: 197965 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:02:12
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 2216
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         006 1204
   Coding: 0000692
   VCID: 387FCE6B4BA650DE6C3-806D
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3663C05341B2A6AE7EF-8063
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Mileage: 197950 km
                    Temperature: 18.0∞C
                    Voltage: 13.90 V
                    Voltage: 13.70 V
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 819002005103087F2D04840570085FC690FC00
   Shop #: WSC 00000 785 00200
   VCID: 8305E987C2E04306091-80D6
   Subsystem 1 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
5 Faults Found:
00323 - Vehicle Inclination Sensor (G384)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 35
                    Time Indication: 0
01135 - Interior Monitoring Sensors
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 69
                    Time Indication: 0
             Freeze Frame:
                    Fault Status: 00110010
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 70
                    Mileage: 197956 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:12:43
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 69
                    Mileage: 197956 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:17:32
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 69
                    Mileage: 197956 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:17:32
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000692
   VCID: 3979CB6F70AC49D693D-806C
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Component: Tuer-SG         006 1305
   Coding: 0000144
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3
   Shop #: WSC 21977 142 74100
   VCID: 3E73D87369826EEEA6F-806B
End   ---------------------------------------------------------------------
HELP !!!!
« Last Edit: January 28, 2018, 08:03:20 am by clemo »
