January 22, 2025, 08:12:23 am
All Things Mk5
Performance Modifications
Which engine mounts for stage 3 GTI
Topic: Which engine mounts for stage 3 GTI (Read 1578 times)
jasam
Always Involved
-Given: 4
-Receive: 1
My Ride:
January 30, 2018, 10:49:43 am »
Hi,
I need to change standard mounts,as they got soft.
There are 4 mounts on engine? 2 for top engine, 1 for bottom(subframe) and 1 dogbome mount?
Which one are most important (to eliminate engine move)?
Last Edit: January 30, 2018, 11:02:19 am by jasam
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: Which engine mounts for stage 3 GTI
Reply #1 on:
February 02, 2018, 12:06:32 pm »
1 x Gearbox
1 X engine block
2 X large dogbone bushes
1 x small dogbone bush
The dogbone controls the fore and aft pendulum motion. The side mounts support the engine weight and control lateral movement during cornering.
Replacing all 3 is recommended for maximum wheel hop reduction and cornering balance.
Prices range from ~£50ish for inserts to £300+ for fully reengineered replacements.
Road use with the occasional squirt - just a dogbone upgrade will be fine for most people.
More serious fast road and track work needs all of them uprating - at the expense of cabin refinement. Vibratechnics are probably the most forgiving ones out there, and also the most expensive. Revo and most other poly mounts the worst for noise and vibration.
jasam
Always Involved
-Given: 4
-Receive: 1
My Ride:
Reply #2 on:
February 02, 2018, 02:43:27 pm »
Thank you thats detailed info
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #3 on:
February 02, 2018, 02:58:12 pm »
Welcs mate. You could try brand new side mounts from VW. They're good for about 1 year - 18 months before they get a bit squidgy again.
All Things Mk5
