Author Topic: Airbag fault: Crash sensor HELP  (Read 1048 times)
Offline saunders400
« on: January 31, 2018, 04:15:13 pm »
My Mk5 3dr has developed an airbag fault.
Had it cleared but came back 2 weeks later.
It’s the crash sensor on the passenger door.
Any ideas on how to fix? Can I buy a 2nd hand sensor and does anyone know the part number?
Dave
Offline SI-R32
  • -Receive: 125
Re: Airbag fault: Crash sensor HELP
« Reply #1 on: January 31, 2018, 06:29:24 pm »
It may not be the actual sensor it maybe you have broken wires in the door rubber, if you remove the plug from the front  pillar  pull the rubber back and look for broken cables.
If it turns out to be the sensor then you'll have to remove the outta door skin to get to it, rivits need to be drilled out as well
