Author Topic: Loose pipe in engine bay?  (Read 1197 times)
Offline jacko17
« on: February 02, 2018, 02:21:19 pm »
Hi all had a loose pipe/tube in my engine bay and lost a tiny bit of oil in the past week, I don’t want to connect the two up just incase they’re not supposed to go together so I just want to make sure. Here a pic of the two.
https://imgur.com/zR4p9Jq
https://imgur.com/tsUpKqA
Offline jacko17
Re: Loose pipe in engine bay?
« Reply #1 on: February 02, 2018, 03:32:34 pm »
Found out that it’s for the turbo boost gauge valve.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #2 on: February 02, 2018, 06:09:25 pm »
You should discover where they connected it...it shouldn't be full of oil. They should've installed a "T" for it up near the hpfp(@ "R" of the intake manifold). Located in step one on this pdf: http://bd8ba3c866c8cbc330ab-7b26c6f3e01bf511d4da3315c66902d6.r6.cf1.rackcdn.com/VW_MKV_GTI_FSI_ECS_Tuning_Vent_Pod_Vacuum_Boost_Gauge_Installation.pdf
If it was connected to the crankcase ventilation...you will get oil. A proper boost tap connected to the CC ventilation may have helped prevent this.
Offline jacko17
« Reply #3 on: February 05, 2018, 07:55:35 pm »
Okay cheers I’ll take a look when I finish work tomorrow.
« Reply #4 on: February 06, 2018, 10:37:13 am »
Looks like it's diesel with that airbox, so slightly different procedures.
