Author Topic: Question regarding rear camber?  (Read 7244 times)
Offline Raj2212
  • -Given: 75
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115142.0.html
« on: February 03, 2018, 02:43:04 pm »
Hi, after some advice
Finally got some spacers to put on.  :party: :party:  I've gone for 12mm spacers for the rear and leaving the front for now.
Would the rear wheels have added camber when the spacers are put on. Or is that done another way. I was looking to add slight camber to the rear wheels to stop them from hitting the arches once fully loaded.
Any help would be appreciated.
Raj
Offline Graham1990
Re: Question regarding rear camber?
« Reply #1 on: February 03, 2018, 02:54:45 pm »
I don’t think putting wheel spacers on will change the chamber of the wheels. I’m pretty sure there are some accentric bolts on the rear arms you can adjust to change the camber on the rear wheels but you probably want them to be set up with the correct equipment. Just eyeing the wheels up might make the car drive a bit funny.
Offline Raj2212
  • -Given: 75
  • -Receive: 20
« Reply #2 on: February 03, 2018, 04:01:25 pm »
Thanks for clearing that up @Graham1990 . I'll have a word with the guys that did my alignment to see if they can do it.
Don't really wanna compromise the ride. Would it be best to leave camber alone??
Offline Graham1990
« Reply #3 on: February 03, 2018, 04:07:25 pm »
If the tyres don’t rub on the arches I would personally leave it as the vw settings say so. But a little bit of negative camber shouldn’t effect the ride or the way the tyres wear to much if they are rubbing on the arch. 👍
Offline chigmuss
« Reply #4 on: February 03, 2018, 09:30:26 pm »
In my experience the 12mm spacers you've gone for Raj should gIve you a very nice stance at the rear without inducing arch rub. Strangely, on a previous Ed30 I had a 15mm (each side) spacers caused a world of pain in terms of rubbing and after a hunter wheel alignment, I discovered the rear sub frame was out by 6mm or so to one side.
If you want to add a small amount of camber you can buy camber bolt kits but I doubt you need them at 12mm.
I have 12mm all round now on my current Ed30 and it sits lovely. Just remember extra length bolts!
Offline Rigsby
  • -Given: 22
« Reply #5 on: February 03, 2018, 09:47:28 pm »
I have rear 15mm spacers on H&R springs......no rubbing yet
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
« Reply #6 on: February 03, 2018, 10:03:15 pm »
Mannn load that camber on, I'm running -4 degrees to tuck 9.5J wheels. You'll be fine with running -2 to -2.5 degrees without having excessive inner tyre wear.
Offline Wardy42
« Reply #7 on: February 03, 2018, 10:37:07 pm »
Running 12mm h&r spacers on the rear, no rubbing and no need to adjust the camber
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #8 on: February 04, 2018, 08:26:33 am »
No need for more neg. rear camber, but you have just increased its understeer...so careful until you have become accustomed to it...if you challenge your Beast.  :drinking:
Easiest thing to do to reduce understeer is raise front tire pressure and lower rear tire pressure.
A stiffer rear ARB works.
Smaller front tires or taller rear tires may help.
More front neg. camber would work if you install a front adjustable camber kit.
But if just a daily driver and going for turning heads...the above should be ignored.  :happy2:
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #9 on: February 04, 2018, 10:34:16 am »
I think you meant it the other way around.  :happy2:
Offline Raj2212
  • -Given: 75
  • -Receive: 20
« Reply #10 on: February 04, 2018, 06:22:02 pm »
Thanks for all the responses.  :happy2: :happy2:
Found some time to get the spacers on the car.
I've chose to leave the camber how it was for now. Love how it looks now and drives fine.
No rubbing  :happy2:
Offline Raj2212
  • -Given: 75
  • -Receive: 20
« Reply #11 on: February 04, 2018, 07:50:44 pm »
Offline Wardy42
« Reply #12 on: February 04, 2018, 09:25:21 pm »
10mm spacers on the front now  and it will be sitting pretty much as good as it gets then
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #13 on: February 05, 2018, 01:41:10 am »
That would go against everything I have ever been told , read, or heard. I always run 2 lbs. less air in the rear. You have any documentation stating I have it wrong please?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #14 on: February 05, 2018, 07:50:41 am »
I'd recommend you guys have a read of this, best explanation I could find. Few posts down
https://www.pistonheads.com/gassing/topic.asp?t=1047380
