Author Topic: Engine rumble at low revs when pulling away  (Read 7695 times)
Offline Ash_89
« on: February 12, 2018, 07:37:40 pm »
Hey guys ,
I was wondering if it’s normal for these engines to sound really rumbely when pulling away
Mostly noticeable when engine is cold
The sound is like when you fit a foam Intake to a none turbo car it has that rumble when flooring it at low rpm
Golf gti bwa 2007/8
Re: Engine rumble at low revs when pulling away
« Reply #1 on: February 15, 2018, 11:19:42 am »
Manual or DSG?
Yes it's a known thing for manuals to 'rumble' when taking up the clutch bite around 1000rpm from cold.    Sounds nothing like what you describe though.
Offline shaunK
« Reply #2 on: February 15, 2018, 09:16:04 pm »
Does it almost feel rough when pulling away and like its going to stall? Mine felt like that and it turned out to be the alternator pulley. Simple to test if its gone and also pretty simple and inexpensive to change.
Offline Rigsby
  • -Given: 22
« Reply #3 on: February 15, 2018, 09:56:21 pm »
Mines started doing this, sounds like mine is coming from the aux belt area.
A little research suggests it could be the alternator pulley.
« Reply #4 on: February 16, 2018, 12:37:17 pm »
Interesting. Hadn’t thought of replacing the alternator pulley.
£83 from VW  :surprised:
Is the nut on there really tight? Easy to get off without an impact gun?
Offline Ash_89
« Reply #5 on: February 16, 2018, 09:48:12 pm »
Good shout on the alternator pulley yeah it does like pulling away il whip the belt off this weekend and test the pulley  :driver:
Offline shaunK
« Reply #6 on: February 16, 2018, 10:32:56 pm »
Pretty easy to get off without removing the alternator with the right tool, I bought mine from ebay similar to this one https://www.ebay.co.uk/itm/BLUE-PRINT-Mounting-Tool-Kit-alternator-freewheel-clutch-For-VW-ADG05506/311998802980?fits=Car+Make%3AVW&epid=1537658071&hash=item48a493ec24:g:hcwAAOSwzXxaA1DJ
Offline Rigsby
  • -Given: 22
« Reply #7 on: February 16, 2018, 10:35:48 pm »
Please post your results on this.
@Ash_89 whipping the belt off is a good idea
Offline shaunK
« Reply #8 on: February 16, 2018, 10:46:33 pm »
Got my pulley from here for £20 by the way https://www.onlinecarparts.co.uk/
Offline Ash_89
« Reply #9 on: February 17, 2018, 07:49:42 am »
Will test the alternator pulley today And report back  :happy2:
Offline Rigsby
  • -Given: 22
« Reply #10 on: February 17, 2018, 09:03:45 pm »
Can the pulley be removed without air tools?
I have a spare alternator so may as well swap the pulley over
Offline shaunK
« Reply #11 on: February 17, 2018, 09:31:01 pm »
With the right tools and a breaker bar yeah its pretty easy
Offline Rigsby
  • -Given: 22
« Reply #12 on: February 17, 2018, 09:33:23 pm »
So breaker bar and that tool you put a link to? Is that all I need?
Offline shaunK
« Reply #13 on: February 17, 2018, 11:29:04 pm »
A spanner also to hold the tool 15mm I think, I followed a guide somewhere for it but yes apart from slipping and taking a chunk out my hand it was a simple job
Offline Rigsby
  • -Given: 22
« Reply #14 on: February 18, 2018, 10:59:40 am »
Thanks I’ll get one ordered 👍🏼
