Author Topic: 2009 Golf Plus TDi - Water in Boot + Drivers Footwell  (Read 2067 times)
NickH
« on: February 13, 2018, 12:02:16 pm »
Hi Guys,
New to the forum.
Recently purchased a 2009 Golf Plus TDi DSG, and have a water ingress issue.
Water is collecting (quite a substantial amount) in the boot floor (underneath the spare wheel/tool kit etc) - Note: I have a passenger side rear fogged outer light
Water is also collecting in the drivers side footwell directly under the matt.
I have done a bit of research on google/here, but wondered if anyone could help me further?
Thanks in advance!
Nick
NickH
Re: 2009 Golf Plus TDi - Water in Boot + Drivers Footwell
« Reply #1 on: February 14, 2018, 01:35:53 pm »
Anyone?
Offline eb198
« Reply #2 on: February 27, 2018, 03:31:12 pm »
behind the rear bumper you have 2 flaps for ventilation, the seals around these can fail. the water in the front might be from a blocked water drain underneath your scuttle panel. however once water gets in the boot it can run down the channels and fill the footwells up. I suggest removing the carpet completely  to dry and prevent mould and check those two areas first. Also check your boot seal for damage or general ageing/wear and tear
Offline eb198
« Reply #3 on: February 27, 2018, 03:31:39 pm »
