Author Topic: K04/K04 hybrid turbo blanket: Yes or No?  (Read 2162 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« on: February 17, 2018, 12:38:55 am »
Has anyone fitted a turbo blanket? If yes, which one and where did you get it?
I'd like to know your opinion. :smiley:
Check this topic for more information: HYDE16 Reviews - PTP Turbo Blankets K04 Lava Turbo Blanket
Re: K04/K04 hybrid turbo blanket: Yes or No?
« Reply #1 on: February 19, 2018, 09:54:53 am »
Not needed on a factory turbo car which has already had proper diligence in heat management.   Not to mention the KO4-061 is a compact unit, so has a ton of heat energy already.  A blanket will do bugger all.
Blankets may be useful in cars that did not have a turbo from the factory, or where a turbo manifold is poorly designed and loses heat / exhaust velocity energy.  None of this applies to the KO4 in the TFSI.
When considering modifications like this, ask yourself: "If this is so beneficial to performance, why didn't VW fit one?".   They didn't fit one because there is simply no benefit vs the cost, and they can be dangerous as well.  They can absorb oil spills and catch fire.   I have experience of that  :thinking:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: February 19, 2018, 01:27:22 pm »
Thank you @Pudding ! Less expenses for me then. :drinking:
« Reply #3 on: February 19, 2018, 03:17:15 pm »
I would only spend money where it counts mate  :happy2:   I have never noticed any difference at all from blankets, ceramic coating, gold tapes or pipe wrapping.
They are exactly the things OEMs consider to avoid engine compartment fires, so if they don't bother with that stuff, neither should we  :smiley:
