Author Topic: Brake Pad Warning Light  (Read 1760 times)
Offline lennshow66
« on: February 25, 2018, 05:13:38 pm »
Hi all,
Just replaced all my brakes but now the warning light is on the dash.
The previous owner of the car or some garage looks like they have cut the connector to the brake pad warning sensor off.
What options do I have here?
4ndy
Re: Brake Pad Warning Light
« Reply #1 on: February 25, 2018, 07:33:05 pm »
Just replaced these because of corrosion causing the dash light. https://www.ebay.co.uk/itm/VW-2-Pin-connector-with-30cm-tail-leads-1J0973802-FREEPOST-Finishing-Kit/323099092060?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
 Easy fit with either solder or included connectors.
« Reply #2 on: February 25, 2018, 07:51:22 pm »
join the wires together when the sensor plugs in or replace loom
get the sensor coded out
