Author Topic: 05 AXX GTI Started with missfire under load now wont start - now running smokey  (Read 5697 times)
To establish if your ECU is standard or remapped, go into 'Advanced ID' in the engine module.  'Successful' and 'Attempted' flash counts will both be 0 if it's standard.  1 or more means it's been remapped.
I would log this lot first:-
Engine speed
Mass Air flow
Lambda control - that's your short term live adjustments, +/- 25%.  Anything more than 10% either way isn't too healthy.
Lambda requested.
Lambda actual - Just to make sure it's running 1 at idle and part throttle, and ~ 0.85 in boost.   Black smoke zone is 0.75 and richer.
Boost requested
Boost actual
Fuel rail pressure requested
Fuel rail pressure actual
Fuel rail pressure difference - easier than getting the calculator out!  5 bar difference over a 100rpm or so is normal. Analog devices take time to react.
Ignition angle - Don't be surprised to see this go negative in boost, it's normal.  Such a massively delayed burn can also cause black smoke.
Throttle valve angle.
Annoying that you can only log 12 things at once, but must be a limitation of the databus rather than VCDS.
Then log these separately:-
Engine rpm
Boost requested
Boost actual
Ignition delay (knock control) cyl 1
Ignition delay  cyl 2
Ignition delay  cyl 3
Ignition delay  cyl 4
Misfire recognition cyl 1
Misfire recognition cyl 2
Misfire recognition cyl 3
Misfire recognition cyl 4
Intake temp
RE: the fault codes, the only one I'd be concerned about is the MAF.  The post cat lambda and charcoal can plumbing faults are common and wouldn't cause excessive over fuelling.  A bad MAF certainly could though.
Offline _dubstar_
Been on the dyno today and a remap from Uber Tuning. Now putting out 242.48hp and 369.78Nm. No smoke and no oil consumption. PCV delete seems to have cured the oil getting in the cylinders.
