Author Topic: MDI Question  (Read 2211 times)
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
MDI Question
« on: March 07, 2018, 08:35:30 pm »
Hi all in my 2008 mk5 i have the factory cd changer fitted & im looking to change it to the factory Mdi armrest type wich i already have purchased https://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-SIROCCO-PASSAT-B7-MMI-UNIT-5N0035341F-5N0-035-341-F/253415167563?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 the problem i cant seem to find an answer to is ref the connecting loom as i have later spec factory phone kit fitted under my drivers seat & connected to my Rns510 dab using the loom already https://www.ebay.co.uk/itm/5N0035728B-5N0035729A-Bluetooth-MDI-Kabelset-Combo-ULTRA-Plug-Play-SDS-A2DP/171229839753?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 / My question is do i still need to buy https://www.kufatec.de/shop/en/volkswagen/golf/golf-5-golf-5-plus-1k/vw-media-in-mdi-interface-harness & will the two harness be ok fitted together, i know the mdi will need coding wich is fine as i have full vcds.
Sorry if this has been asked before but i read loads on the net on different forums & i cant seem to find a s simple answer.
Offline Sessions
Re: MDI Question
« Reply #1 on: May 14, 2018, 10:13:35 pm »
Hi. Unless you can buy the plug on its own, and wire into the other loom. I think you will have to plug all the looms in not sure if you will squeeze it all behind the stereo though.but I’m sure you won’t be the only one this must have been covered before.
Offline Pashka
Re: MDI Question
« Reply #2 on: May 15, 2018, 09:18:44 pm »
if your combo loom has plug for mdi you don't need any other looms.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
