Author Topic: Oil consumption  (Read 2097 times)
Offline Dij303
Oil consumption
« on: March 11, 2018, 10:20:51 am »
Hi. Has anyone had this problem? I have a 2005 GTI, recently had oil changed etc. 2k miles later the oil pressure light came on and it’s just below the min mark. Doesn’t appear to be any leak and no blue smoke from the  exhaust. Is this normal? Thanks
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Oil consumption
« Reply #1 on: March 11, 2018, 08:27:37 pm »
Firstly, did you originally check the level without running the engine following the oil change? If so...the drop may be from filling the oil filter housing once it did get started. But being at the bottom wouldn't trigger a CEL with an oil pressure icon/code.
Oil consumption; Oil could be pooling in the fmic and boost plumbing for now, but at WOT you may see some smoke. If not smoking daily while driving tamely, the leak is likely not from the valve train going directly into combustion. This means you may have a busted valve cover-internal splash plate that seals the evap and pcv reroute to the turbo inlet... or it could be a leaking turbo seal.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Oil consumption
« Reply #2 on: March 12, 2018, 07:38:31 am »
Who doesn't check their oil for 2,000 miles?
Yes, they use oil
Yes, it's normal
Yes, you need to check it and top it up a lot more often
Offline mjmallia
Re: Oil consumption
« Reply #3 on: March 13, 2018, 02:12:28 pm »
As above.........but found mine has balanced out since moving from 5w30 to 5w40
Mike
South Coast
Offline Dij303
Re: Oil consumption
« Reply #4 on: March 15, 2018, 12:28:31 pm »
Yes, they use oil
Yes, it's normal
2k seems low for oil consumption but fair enough. This is my first GTI so if this is normal then lesson learnt. Cheers
Offline Dij303
Re: Oil consumption
« Reply #5 on: March 15, 2018, 12:31:57 pm »
Yeah I went for 5w40 when I topped it up. Cheers
