If you got them for as little as £120 it's maybe worth paying a bit extra to get them refurbished with new seals etc.I got some PP calipers off ebay for a decent price (see main thread) but I've had problems for a while and I'm pretty sure one of the pistons is sticking. Point is, I've spent dead money on fitting the calipers, knackering discs, and now I'm replacing the lot with brand new calipers pads and discs. The calipers coming off will of course be getting a full rebuild before I move them on.I just think for a little extra cash you can have the peace of mind that you're not going to end up with costly issues. I risked it, and lost out. Lesson learnt!
Quote from: AJP on March 15, 2018, 08:46:51 pmIf you got them for as little as £120 it's maybe worth paying a bit extra to get them refurbished with new seals etc.I got some PP calipers off ebay for a decent price (see main thread) but I've had problems for a while and I'm pretty sure one of the pistons is sticking. Point is, I've spent dead money on fitting the calipers, knackering discs, and now I'm replacing the lot with brand new calipers pads and discs. The calipers coming off will of course be getting a full rebuild before I move them on.I just think for a little extra cash you can have the peace of mind that you're not going to end up with costly issues. I risked it, and lost out. Lesson learnt! Any idea what you might sell the PP calipers sell for?
Quote from: Rob1 on March 15, 2018, 08:50:31 pmCheers guys I’ll look into that. On another note do you guys know if the mk7r discs are a straight swap for the mk5?With the bigger calipers from the R32/6R/S3/Cupra, yes. With factory fitted calipers on a GTI, no.
Quote from: Shoduchi on March 15, 2018, 08:57:54 pmQuote from: Rob1 on March 15, 2018, 08:50:31 pmCheers guys I’ll look into that. On another note do you guys know if the mk7r discs are a straight swap for the mk5?With the bigger calipers from the R32/6R/S3/Cupra, yes. With factory fitted calipers on a GTI, no. Thanks Shoduchi, what was would the following be a straight swap on my mk5 or would I need anything else?
Quote from: Rob1 on March 15, 2018, 09:04:44 pmQuote from: Shoduchi on March 15, 2018, 08:57:54 pmQuote from: Rob1 on March 15, 2018, 08:50:31 pmCheers guys I’ll look into that. On another note do you guys know if the mk7r discs are a straight swap for the mk5?With the bigger calipers from the R32/6R/S3/Cupra, yes. With factory fitted calipers on a GTI, no. Thanks Shoduchi, what was would the following be a straight swap on my mk5 or would I need anything else?I think you'll just need bigger dust shields (Or whatever they call them)The Clubsport S disks will go on if you don't mind dropping £300 on them
Quote from: neilw on March 16, 2018, 09:42:19 amQuote from: Rob1 on March 15, 2018, 09:04:44 pmQuote from: Shoduchi on March 15, 2018, 08:57:54 pmQuote from: Rob1 on March 15, 2018, 08:50:31 pmCheers guys I’ll look into that. On another note do you guys know if the mk7r discs are a straight swap for the mk5?With the bigger calipers from the R32/6R/S3/Cupra, yes. With factory fitted calipers on a GTI, no. Thanks Shoduchi, what was would the following be a straight swap on my mk5 or would I need anything else?I think you'll just need bigger dust shields (Or whatever they call them)The Clubsport S disks will go on if you don't mind dropping £300 on themYou don't need bigger dust shields. It's fine with the factory fitted ones. I'm using 350 mm discs with factory dust shields.But if you really want to get bigger dust shields you can fit the dust shields from the R32/6R/S3 8P/Cupra 1P.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F232548900802Would these be suitable for my S3 calipers?
