Author Topic: Boost Freaking out and high fuel pressure target is just 110 bar  (Read 6391 times)
Re: Boost Freaking out and high fuel pressure target is just 110 bar
« Reply #15 on: March 26, 2018, 09:54:59 am »
Maybe the GIAC map is just smoother.  Smooth is always faster than aggressive wheel spinning spikes.....but it just doesn't feel it on the butt dyno.
I agree...I never was comfortable with boost holding at 25+ psi throughout the rev range with that DM open-loop tune...obviously it was never beneficial as well.
Open loop boost control?  That really is a BAAAAAD idea.  Probably just as well you moved away from DM then if that is their tuning strategy.
Offline dreadaccind
« Reply #16 on: April 01, 2018, 12:36:32 am »
Boost in from the turbo to the metal - bottom nipple.
Boost out to wastegate - to the side output.
It appears to be pictured correctly.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #17 on: April 01, 2018, 05:52:19 am »
Yes! Boost target was set for max boost throughout the rev range....no taper. When it shifted boost spiked each time above max boost. I ran it less than two years and they sent everyone a new closed loop version but it didn't run right. Then they shut down so I never got their help in tweaking that closed loop tune to make it run.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #18 on: April 01, 2018, 05:54:15 am »
Sorry, but I have no idea what you are referring to...more please?
