Author Topic: VW Racing Big Brake kit product review  (Read 122862 times)
Offline xht20
Re: VW Racing Big Brake kit product review
« Reply #180 on: April 17, 2010, 11:34:50 pm »
Thanks for the advice. In 2 days i will receive the new kit from VWR and then i will look more closely to this. Now i have BBS CH wheels and i understood that they have conical seat
Offline xht20
« Reply #181 on: April 26, 2010, 09:55:29 pm »
Installed today the new kit, i did everything as they told me, torqued every bolt. Still has that wobble, but is not segnifiant as the first kit. Under harder acceleration at speeds beyond 120km/h the sterring vibrates.
I think i know what's the problem. I attached a picture of the bolts from BBS and the bolts that i received in the brake kit. You see the difference?
« Last Edit: April 26, 2010, 09:57:54 pm by TEFF »
Offline Poppa Dom
« Reply #182 on: April 26, 2010, 11:16:09 pm »
Yes, you need to be running on the 60 degree bbs bolt not the radius bolt if running after market wheels.  :happy2:
Offline xht20
« Reply #183 on: April 26, 2010, 11:26:34 pm »
I found out that H&R has 60 degree tapper bolts that are identical with the ones received from BBS, only that they have the lenght of the ones received from VWR. Tomorrow i will order them. Hope that this solves the problem :D
Offline xht20
« Reply #184 on: April 27, 2010, 09:23:19 pm »
today i changed the bolts with ones that has conic seat and it still has the same wobble. I don't know why. On the rear i have R32 brake setup with Zimmermann discs (tomorrow i will change them with OEM ones, it might be that the ones from rear are not good). Is there a chance that the front brake kit with the big one from rear are too much for the brake fluid pump?
« Reply #185 on: April 27, 2010, 09:52:46 pm »
u have pm Teff
Offline chungster
« Reply #186 on: April 27, 2010, 10:19:38 pm »
i really hope you've not inadvertantly buggered up the bolt holes in the hub from fitting the kit first time round and driving at high speed with insecure wheels due to wrong bolts being used.
« Reply #187 on: April 27, 2010, 10:27:00 pm »
i think he might have but i would get all 4 wheels in the air and then spin the wheels to see if they wobble at all
Offline xht20
« Reply #188 on: April 28, 2010, 02:55:22 am »
today i will try the brakes with another wheels, and see if there are any improvements.
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #189 on: April 28, 2010, 08:08:54 am »
Are there any markings on the top of the VWR longer wheel bolts? Pics?
Offline jonnyc
  • Herrooooo!
« Reply #190 on: April 28, 2010, 08:17:05 am »
Sorry if I have missed this..
Why do you have to run different/longer bolts..?
« Reply #191 on: April 28, 2010, 08:51:23 am »
I have asked him to put the car in the air and spin the wheels to see if they wobble and if he can get someone in the car to get the wheels up to speed to see if they wobble. He told me wheels are new too
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #192 on: April 28, 2010, 09:30:12 am »
Because the new discs bells have a built in spacer to allow them to fit with the OEM wheels like the Pescara.
Offline xht20
« Reply #193 on: April 28, 2010, 02:47:11 pm »
Today i went to another service and did the perfect bleed of the calipers. All the services didn't knew that you had to do the bleed on the both sides of the calipers. And that's the cause of the wobbling. Because the caliper wasn;t pushing with the same pressure on the both sides of the disc. I still feel a little vibration, but i will wait to see if it dissapears after some bedding.
The mechanic here told me that is possible that the discs were deformed because of the not-equal pressure pushed on the by the caliper. If this is true, i will buy another set of discs from VWR.
Another thing, about the pedal feel. After this perfect bleeding the pedal response is very prompt. I hit the steering wheel with my head after the braking :)) :signLOL:
« Reply #194 on: April 28, 2010, 03:19:53 pm »
 :jumpmove: nice one i did say to you have you bled them correctly  :signLOL:  :rolleye: oh well we got there in the end  :happy2:
