Author Topic: Never seen or heard fan running.  (Read 3547 times)
Re: Never seen or heard fan running.
« Reply #15 on: June 15, 2018, 06:20:02 pm »
You generally won't hear them unless you are sat in traffic in the height of summer with the AC set on LO.
There are a few trigger points for the fans for just engine cooling (AC off).  Stage 1 is usually around 95 degrees at a slow speed, stage 2 is around 105 and full pelt is usually around 120.  It's very rare you will hear them running fast enough to hear them in the car, except for my first sentence  :smiley:
As I say, if you have VCDS or OBD11, do an output test on the fans to confirm they are loving life and got your engine's back  :happy2:
Offline Mk5. EWC
« Reply #16 on: June 18, 2018, 06:37:59 pm »
Which ones am I looking for? I've had a quick look over all of them and they all seem ok. What's the next step if it's not the fuses? https://ibb.co/cNJexy
