Author Topic: Electrical issue battery draining!!!  (Read 782 times)
Jimlad91
« on: March 17, 2018, 08:26:18 pm »
Help needed! I have recently bought a gti and found out that the electrics are a bit dodgy sometimes the heater only blows hot air and driver's side head light doesn't always come on first time. Anyway the first month the battery was fine but now have to keep charging it up. I have tested current being drained from battery with everything off at 0.21 amps removed fuses 1 by 1 and after removing fuses F3 and F53 dropped to 0.07A
 F53 - (50A) Fascia fuse box/relay plate 1 (F32-F37), fascia fuse box/relay plate 2 (F4)
F3 - multifunction control module 2
(Seems to control central locking don't know what else)
Where do I go from here???
Also I turned the stereo off as I thought it could be draining power but it won't turn back on now
« Last Edit: March 18, 2018, 08:07:07 pm by Jimlad91 »
