Author Topic: Factory alarm not working  (Read 3074 times)
Offline akispap
« on: March 25, 2018, 12:05:11 am »
Hey all, I recently bought a used GTI and it has factory alarm fitted. It seems to me though it doesn't work at all.
I get the continuous red led on the door when I lock the car, no chirping or horn confirmation on lock/unlock,
I tried to activate the motion sensors didn't work as well. Also I scanned the car and it showed me the following errors:
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 989002085103007F2D000F0FF0021FC2308000
   Shop #: WSC 01367 785 00200
   VCID: 800FE68BD3F6581E143-80D5
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:      IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 200438 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:08:36
00323 - Vehicle Inclination Sensor (G384)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 200438 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:08:36
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 200438 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:08:36
I checked the fuse it seems to be fine.
Any solutions? Will buying a new horn fix all the above?
Offline Ant b
Re: Factory alarm not working
« Reply #1 on: March 25, 2018, 07:20:52 pm »
Horn has failed,very common I have a spare if wanted
red mk5 golf gti ks05 fak,ram air intake,3” downpipe/decat,dv+,bcs rev ll exhaust stage 1 remap.coilovers,whiteline rarb and depo projectors,
Edition 30 front splitter,r32/gti rear,r32 side skirts
Soon to be r tech stage 2
Offline akispap
« Reply #2 on: March 25, 2018, 10:11:31 pm »
But is it normal for the rest to not show up working properly?
Offline dreadaccind
« Reply #3 on: April 04, 2018, 04:44:06 am »
When you installed the ultrasonic modlue didnt you have to cut open the slits in order for the sensor signals to pass through because on a e90 w/o the factory alarm the slits are not cut out..
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #4 on: April 04, 2018, 08:11:22 am »
YES
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline akispap
« Reply #5 on: April 05, 2018, 02:18:21 pm »
I see. Okay I'm gonna take out the siren and replace it, see if it fixes everything!
