Author Topic: mk5 gti cruise control retrofit  (Read 1274 times)
Offline eb198
« on: March 29, 2018, 07:37:16 am »
Morning guys,
Iv got  a mk5 gt tdi 2008, manual no mfsw or cruise control but highline dash factory fit. Does this mean I can retrofit cruise control and mfsw without having to change the steering module and wiring or will it still be required?
Cheers for any help
willni
Re: mk5 gti cruise control retrofit
« Reply #1 on: March 29, 2018, 09:09:32 am »
Think it's 07 on they put the cruise control wire in, not sure about the module.
Offline samba2321
« Reply #2 on: March 29, 2018, 06:39:12 pm »
Does this anything other than the cruise control switches if the wiring is there?
Admin Notice: Image Too LARGE!
Offline Octoparrot
  • -Receive: 102
« Reply #3 on: March 29, 2018, 06:51:12 pm »
As said you'll probably just be able to fit the cruise stalk and code it in to get it to work, you'll have to see what steering module you've got to see if it's compatible with the MFSW, you can find out which you have by scanning it with vag com/ vcds or take a look at it when you fit the cruise stalk as you have to partially remove it to do so.
Offline samba2321
« Reply #4 on: March 30, 2018, 07:29:33 am »
Cheers, my mates got vag com so I'll get him to scan it for me.
