Author Topic: Anyone know if the Passat B6 & TT mk2 hubs are the same?  (Read 5315 times)
Offline Christiank
  • -Receive: 39
« on: April 03, 2018, 02:09:24 pm »
Hi, does anyone in here know if the Passat B6 alloy wishbones and hubs make you a few inches wider than if you're using the Audi TT mk2 ones?  :thinking:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Anyone know if the Passat B6 & TT mk2 hubs are the same?
« Reply #1 on: April 03, 2018, 11:49:51 pm »
Those are the same as the S3 hubs. TT have different hubs.
Offline Bodyboarder81
  • -Given: 35
« Reply #2 on: April 04, 2018, 09:35:11 am »
So is it the hub that you get the extra track width from or the arms ?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #3 on: April 04, 2018, 11:11:19 am »
I can't remember exactly but IIRC the TT has specific hubs and arms and you get the extra track width from the hubs but you also need longer steering column arms when you retrofit the TT hubs and arms.
  • -Given: 35
« Reply #4 on: April 04, 2018, 11:22:11 am »
AH ok makes sense  :happy2:
I have ttrs ( not sure there’s a difference to normal TT?) control arms and ball joint/camber adjuster on my gti but standard hubs and steering rack ect .... just trying to figure out if my track width has changed from standard or not .....
« Reply #5 on: April 04, 2018, 01:42:39 pm »
Measure your length, ooer, and I’m compare with mine  :smiley:
I’ve never seen wide track without longer arms because they are what control the roll center.  Doing it with a wider hub is no different to spacers, but with VAG, who knows, anything is possible!
I believe the TTRS has a shorter steering rack and longer tie rods to compensate for the extra length, or maybe the other way round.  Speak to Alex at AKS, he’s done it on his VRS I believe.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: April 04, 2018, 01:46:32 pm »
That info is available in this forum in a topic about the different hubs and control arms for the PQ35 chassis. Have a look around the forum. :wink:
  • -Given: 35
« Reply #7 on: April 04, 2018, 02:53:19 pm »
Tell me where you going to take the measurements from  :happy2:
Cheers kev
Offline Christiank
  • -Receive: 39
« Reply #8 on: April 04, 2018, 09:11:27 pm »
Hi guys, talked to someone about this yesterday and the TT setup gives you 25mm more track width and the Passat setup gives only 6mm width
I belive it's needed both wishbones and hubs to get the full width .. I've got both passat hubs and wishbones installed on my mk5, but really thinking about getting the TT setup instead
  • -Given: 35
« Reply #9 on: April 04, 2018, 10:50:59 pm »
I have the ttrs arms and standard gti hubs .... for reference I’d like to take some measurements for anyone else thinking of going this way .... just need to know where to take measurements from so we can compare  :happy2:
« Last Edit: April 05, 2018, 06:58:23 pm by Bodyboarder81 »
« Reply #10 on: April 05, 2018, 01:01:23 pm »
From the middle of the stub that goes into the console bush to the ball joint  :happy2:
  • -Given: 35
« Reply #11 on: April 05, 2018, 07:25:37 pm »
50 cm diagonally from control push centre to ball joint centre .. my camber is maxed out on the adjuster ... so I think that gives me around 10mm longer .
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #12 on: April 05, 2018, 08:42:15 pm »
The TTRS has the same control arms as the TT.
« Reply #13 on: April 06, 2018, 10:33:24 am »
Sorry, I meant the front bush to the ball joint, so a straight axis to measure!
I did have a quick scout online and someone measured 14mm longer than a GTI arm.  That would certainly give you a bit of extra camber!
  • -Given: 35
« Reply #14 on: April 06, 2018, 11:08:05 am »
Ok I’ll take another measurement later ..... just can’t see how you could use the standard drive shafts if the arms 14mm longer!?
