Author Topic: Dash cam, how to route?  (Read 3026 times)
Offline ninjaGTI
« on: April 08, 2018, 07:47:41 am »
Hi,
I would like to know if anyone else has installed a dash cam, and if so, where do you route the wires? Mine is powered by a usb connector which is powered by the 12v cig lighter slot.
Any guides or suggestions?
Regards,
Ash
2006 MK5 GTI
Running stock
Recent Oil filter Change, Air Filter Change, Pollen Filter & Fully Synthetic oil
Offline Pashka
Re: Dash cam, how to route?
« Reply #1 on: April 08, 2018, 11:27:24 am »
Hi,
Regards,
Ash
From the fuse box via pillar/roof to around the mirror. Just find unlive free fuse, or use inline fuse.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
4ndy
« Reply #2 on: April 08, 2018, 02:49:24 pm »
ebay  253544154564 tap into lighter wiring under ash tray. Wire coat hanger to pass the cable through dash.
 Up A pillar and along screen
 A pillar can be  removed to hide the cable or get some sticky cable guides.
 Cable can be pushed under the A pillar trim but this WILL hinder the air bag
 I removed the A trim and used butyl to fix the cable in place Will NOT move.
Double sided tape may do just the same job
 Push the cable under the headlining with a trim tool  All done
  Just replaced my dash cam as the  old one was starting to fail
 Still had to install new cable with new camera  :rolleye:
Offline ninjaGTI
« Reply #3 on: April 09, 2018, 12:58:19 pm »
Hi,
Regards,
Ash
Does this interfere with the airbag?
2006 MK5 GTI
Running stock
Offline ninjaGTI
« Reply #4 on: April 09, 2018, 12:59:15 pm »
Is there any other way to do it without messing with the airbag?
2006 MK5 GTI
Running stock
4ndy
« Reply #5 on: April 18, 2018, 05:05:46 pm »
sorry for late response. You can tuck the cable under the rubber seal running up the A pillar
