November 26, 2024, 10:35:51 am
All Things Mk5
Sat Nav and Car Audio
Battery drain question....
Topic: Battery drain question.... (Read 2204 times)
DanBoy
Always Involved
-Given: 2
-Receive: 3
My Ride:
April 21, 2018, 01:33:18 pm »
I’ve got a 2004 Mk5 Golf which I’ve now just installed a RCD330 Apple car play unit now the unit seems to turn on and off with the ignition key, my question is will I still have the battery drain issue?
DanBoy
Always Involved
-Given: 2
-Receive: 3
My Ride:
Re: Battery drain question....
Reply #1 on:
April 22, 2018, 10:50:00 am »
Well I managed to answer my own question today as the Golf was dead this morning, managed to find my canbus gateway in the end as a lot of posts said it was in the footwell but on my car it’s behind the ashtray, hopefully after a jump I’ll have it working again now I’ve swapped my gateway
doylebros
Just look at my post count
-Given: 44
-Receive: 309
Reply #2 on:
April 22, 2018, 11:43:39 am »
The new can gateway will need coded or you may find issues which aren't faults so keep the old one and find someone with access to VCDS to tick the right boxes.
ballcrusher
Always Involved
-Given: 0
-Receive: 1
Work in progress
Reply #3 on:
June 29, 2018, 02:48:35 am »
I installed the steering wheel interface..connect 2 on to my pioneer head unit and that stopped my battery drain as crazy as that sounds
Desperados
Reply #4 on:
July 29, 2018, 09:42:14 am »
i have to replace mine to , what gateway did you buy ?!
All Things Mk5
