Author Topic: Please help! ABS PROBLEM  (Read 2334 times)
Offline Apearcey
« on: April 29, 2018, 09:50:22 am »
Okay here goes my problem... Last year a friend tried to code me a key for free using some dodgy chinese OBD2 plugin thing. I had no idea what he was doing but I trusted him as he worked for Audi. Anyway.. He plugged this thing in, played with a few things and BANG. Engine cuts out, won't start, original key won't work, new key won't work.. Nothing.
Took the car to an electronics specialist who couldn't figure out the problem either so they turned off the immo just so I could take it home. When the car started back up I had no ABS/ESP and the car has been like that since.
I have tried everything under the sun I can think of the fix this issue. I've had the entire steering rack changed, I have changed the steering sensor under the steering wheel, I have just ordered a new clock spring/squib for behind the steering wheel to change. I have changed the ABS pump and module NOTHING IS WORKING.
I have come to the point now where I actually hate driving the car. Please someone help me...
Sunday,29,April,2018,08:55:17:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ6W013892   License Plate:
Mileage: 201100km-124957mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 65 72
VIN: WVWZZZ1KZ6W013892   Mileage: 201100km-124957miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Not registered 0011
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: None
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2233616
   Coding: 0403000318070160
   Shop #: WSC 00774 210 84121
   VCID: 63C274CEA2CEF85C65-8036
2 Faults Found
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 201059 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:27
             Freeze Frame:
                    RPM: 837 /min
                    Load: 15.7 %
                    Speed: 0.0 km/h
                    Temperature: 71.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
Readiness: 0010 0001
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AT
   Component: ClimatronicPQ35 066 0606
   Shop #: WSC 00000 000 00000
   VCID: 79FE36A63042128C5F-802C
No fault code found.
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0F3XX-
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 377AF09E46D6C4FCE9-8062
   Subsystem 1 - Serial number: 6332MSME0A246874C
   Subsystem 2 - Serial number: 6342MSME0A68637AM
   Subsystem 3 - Serial number: 6351HSME07500176-
   Subsystem 4 - Serial number: 6361HSME0759510E9
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000042
   Shop #: WSC 01279 785 00200
   VCID: 76E43D9A015C7DF432-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   VCID: 6ED415FA790C4534FA-803A
1 Fault Found
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056080E26
   Coding: 3DBF0340050003
   Shop #: WSC 01206 210 45725
   VCID: 2A5CD9EA8564691466-807E
4 Faults Found
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 54
                    Mileage: 201059 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:16:24
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 201059 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:16:25
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 54
                    Mileage: 201059 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:16:50
01304 - Radio
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Reset counter: 94
                    Mileage: 201059 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:17:58
Address 25: Immobilizer
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver        Labels: None
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2348
   Coding: 0000692
   VCID: 3664FD9A41DC3DF4F2-8062
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.068 H07 1806
   Shop #: WSC 61124 001 1048576
   VCID: 3566FA965CDA36ECFB-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 18F800087F2C8F0F485FC69010CC
   Shop #: WSC 01357 210 01865
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
1 Fault Found
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: None
   Part No: 1K0 959 702 K
   Coding: 0000692
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2423
   Coding: 0000144
   VCID: 3362C48E52AE28DCD5-8066
Address 65: Tire Pressure
Cannot be reached
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 3460C79257A02FE4CC-8060
End-------------------------(Elapsed Time: 01:43)--------------------------
Offline scottrobertson377
  • Newbie
Re: Please help! ABS PROBLEM
« Reply #1 on: December 09, 2020, 09:38:18 am »
Hi, don't know if you resolved this. I had an issue with my abs which showed as abs/esp on dashboard and it was a bad fuse due to water ingress...
