Author Topic: Replacing brake lines and fluid  (Read 2023 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« on: May 01, 2018, 08:16:02 pm »
evening, I've got some braided lines and two litres of new brake fluid.
What's the best way of changing both the lines and fluid at the same time?
Should i bleed out all of the fluid from one calipers, replace all of lines and then pour in the new fluid and then bleed all corners?
Will two litres of fluid be enough to do this job?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2c92krqegp787a77tdvq2r9lfg&/topic,19740.0.html
Re: Replacing brake lines and fluid
« Reply #1 on: May 01, 2018, 08:55:35 pm »
Change lines then bleed. 1L should do it
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #2 on: May 01, 2018, 09:13:33 pm »
but remove all of the current fluid before changing the lines?
« Reply #3 on: May 01, 2018, 09:20:07 pm »
No need to do that.
4ndy
« Reply #4 on: May 02, 2018, 06:33:32 am »
speed bleeders, a gift from the gods :happy2:
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #5 on: May 02, 2018, 10:45:55 am »
No need to do that.
But won't fluid just leak out when I replace the lines?
Offline mayesj86
  • Candy white ED30
« Reply #6 on: May 02, 2018, 02:16:18 pm »
No need to do that.
A very small amount will but at that point there is no pressure in the system so wont run out. 1L will be more than enough t purge what little air will be in the system.
