Author Topic: Decent sat nav?  (Read 5939 times)
Offline slynch23
Decent sat nav?
« on: May 01, 2018, 10:38:14 pm »
Could anyone point me in the direction of a decent sat nav ? There seems to be a lot of knock offs on eBay and it’s hard to tell what the good ones are. Thanks in advance
Offline Dude2016
Re: Decent sat nav?
« Reply #1 on: May 02, 2018, 03:34:47 pm »
Hey dude I got ahead unit for mine witch is apple car play I use the maps via my I phone. But not as cheap as a sat nav
Offline jgalla89
Re: Decent sat nav?
« Reply #2 on: May 02, 2018, 04:16:50 pm »
Which one have you got, I'm currently looking into this as well?
Offline slynch23
Re: Decent sat nav?
« Reply #3 on: May 04, 2018, 02:26:27 pm »
Thanks for the reply mate, but I’m after the actual factory fitted one hat came from Volkswagen. I can’t seem to find the name of it to get the correct one.
Offline mart.
Re: Decent sat nav?
« Reply #4 on: May 04, 2018, 03:33:09 pm »
RCD330? You use your phone as the sat nave with google maps. That's about £160 with bluetooth.
RNS510 has nav built in but is probably about £350
  • -Receive: 691
Re: Decent sat nav?
« Reply #5 on: May 04, 2018, 04:43:43 pm »
Older RNS510 (rev A, B, C) pre-led backlight are around £300. LED ones with better processors and HDDs are £400 ish, and then the latest SSD & DAB ones are £550.
I’m selling an LED one, rev Q in the parts section  :smiley:
Offline slynch23
Re: Decent sat nav?
« Reply #6 on: May 04, 2018, 08:46:06 pm »
Thanks for the info mate. Would this be an easily installation process? I’m less than a week into ownership of my gti so still new to everything. At the moment I think I have a dodgy eBay knock off in there (still not sure, but feels really chea, doesn’t feel or look like a vw product). Would installing the antenna etc be relatively straight forward?
  • -Receive: 691
Re: Decent sat nav?
« Reply #7 on: May 04, 2018, 10:15:49 pm »
It’s very easy mate. Literally out with the old, in with the new. The GPS receiver just tucks up into the dash and the radio aerial plug and standard power/speaker harness just plug into the back of the RNS510 and off you go.
I would recommend buying a new stereo surround trim panel from VW as they break very easily when removing it. Only about £20.
Offline slynch23
Re: Decent sat nav?
« Reply #8 on: May 07, 2018, 12:06:11 pm »
Cheers mate. What about Bluetooth? I read somewhere that I may have to install a receiver or something? Or is that already in the head unit?
Offline Bodyboarder81
  • -Given: 35
Re: Decent sat nav?
« Reply #9 on: May 10, 2018, 03:06:52 pm »
Just buy mine ..... has everything  :happy2:
Check the for sale section
Offline andyR43
Re: Decent sat nav?
« Reply #10 on: May 10, 2018, 04:05:52 pm »
/\  /\  This  /\  /\
Keeping it original..............or not!!
  • -Receive: 691
Re: Decent sat nav?
« Reply #11 on: May 10, 2018, 04:16:32 pm »
No Bluetoothache, you need a separate box and harness for that.  That applies to all of the VW RNS510s, certainly up to MK7 at least.
Offline slynch23
Re: Decent sat nav?
« Reply #12 on: May 10, 2018, 07:44:01 pm »
I’m a bit confused.. there is menu for “phone” on the one you have for sale. Is this useless then?
Offline TheBALDpuma
Re: Decent sat nav?
« Reply #13 on: May 10, 2018, 08:33:35 pm »
I got the cheapest, decent brand, Android Auto unit I could get.  It's not perfect in non-Android auto mode, but works very well for sat nav and spotify.  No car nav can touch google maps.
Offline PatchySan
  • -Receive: 59
  • Gracie!
Re: Decent sat nav?
« Reply #14 on: May 10, 2018, 09:27:09 pm »
Yes it will not function unless you install the separate Bluetooth module. If the idea of wiring a separate Bluetooth module is not your thing then you're probably better off purchasing the RNS310/315 instead which has Bluetooth built-in but will still need an external microphone. The RCD330 with App Connect has both Bluetooth and Microphone built-in and will pair with your smartphone to have Apple Maps/Google Maps/Waze navigation displayed on the unit.
