Author Topic: How do I get VCDS?  (Read 2029 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
How do I get VCDS?
« on: May 02, 2018, 04:40:47 pm »
Hi, I'll shortly be replacing the brake fluid and want to use VCDS to activate the ABS unit to ensure as much old fluid is removed from the system as possible.
Where can I get VCDS from? I've seen a few items for sale on Amazon and ebay but want to make sure I get something that will allow me to activate the ABS unit to flush out the fluid.
Can anyone give me a recommendation?
Offline Octoparrot
  • -Receive: 102
Re: How do I get VCDS?
« Reply #1 on: May 02, 2018, 08:50:54 pm »
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #3 on: May 02, 2018, 09:19:41 pm »
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #4 on: May 02, 2018, 11:39:48 pm »
There are but they are clones, not supported by Ross-Tech
I have OBDeleven Pro, not sure if it will do the ABS purge but apparently it does a lot of basic settings etc so it may do.
It's a dongle which was £66 off eBay but you need an Android phone/tablet with an internet connection for it to work.
There is a forum for it so you could ask the question before you buy? edit - http://forum.obdeleven.com/thread/64/brakes-bleeding
https://www.ebay.co.uk/itm/OBDeleven-PRO-Audi-VW-Diagnostic-OBD2-CAN-VAS-VCD-VAG-COM/273189505775?epid=1159491923&hash=item3f9b5d0aef:g:CKcAAOSwcOFWbC8U
https://obdeleven.com/en/
« Last Edit: May 02, 2018, 11:58:16 pm by GVK »
Offline Octoparrot
  • -Receive: 102
« Reply #5 on: May 02, 2018, 11:42:56 pm »
Or ask on the forum if a vcds owner near by will come and do it for you.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #6 on: May 03, 2018, 07:35:13 am »
Full VCDS clones can be had from as little as £20 that will do the job perfectly fine.
Offline colesey
  • -Receive: 89
« Reply #7 on: May 03, 2018, 08:48:14 am »
I have a Carista - it’s good for basic health checks and adaptions but ultimately limited in functionality. I should get VCDS but likely a clone cable as the original is just too expensive for my needs.
