Author Topic: Question about big turbo kits  (Read 4043 times)
Offline tigamilla
« on: May 06, 2018, 09:11:58 pm »
Hi guys, can anyone with big turbo knowledge please answer the following with regards to big turbo kits:
- How does something like the Nortech kit fit to the downpipe given it has an external waste gate?
- Is it possible to use a sports cat downpipe with a big turbo?
In the early stages of research so any help would be appreciated, thanks!
Sent from my CLT-L09 using Tapatalk
Manual MK6R with TTE420 and long live forums!!
Offline th3_f15t
  • -Receive: 183
Re: Question about big turbo kits
« Reply #1 on: May 07, 2018, 07:25:17 am »
From my own research, you'll need a down pipe to suit the turbo of choice as not only do they have external waste gates but also have a different bolt pattern for the mating flange. You can use a sports cat with any setup I believe, as considering the tighter MOT regulations that have just come in it seems silly not too!
More points I have learnt over the time I've been looking into this:
- When you run over 400bhp through a CDL engine (or similar K04 based engines) you really are into the territory of blowing stuff up so forged internals are a must
- If your starting with a K03 based car, you'll need forged internals much sooner
- Transmission and chassis upgrades need to be factored in as well
A hybrid K04 solution like the TTE420 will grant you around the 400bhp limit without the need to rebuild everything. That's the route I've taken for now, least till I can source a second engine to build up in slow time. Even doing the work myself it's going to be expensive...
Offline tigamilla
« Reply #2 on: May 08, 2018, 11:42:09 pm »
Thanks for the info, so the downpipes are also custom jobs? I can see why this gets expensive.
I've also got a TTE420 on a CDL and it's got me thinking, well as some of the supporting mods are already in place, why not go the whole way...?
Where are you doing your research? Seems to be almost no information around unlike the pages and pages available on stage 2 / hybrid level upgrades.
« Reply #3 on: May 10, 2018, 02:34:48 pm »
Do Nortech do a full kit?  I can only see a tubular manifold for a Golf R.
Can you weld and do you have stainless tube cutting equipment?  Making a DP is easy if you have the kit, especially with V band flanges.  I would route the wastegate dump back into the DP rather than a silly 'race car' screamer pipe.   The noise will quickly piss you off and exhaust gas will get into the cabin, not to mention being illegal.  And we all know Carbon monoxide is the silent killer.
You don't need a fancy tig welder, but back purging is a good idea to prevent 'sugaring', which can break off and chip turbine wheels.  I made a DP for my VR6 turbo years ago with a cheap MIG welder from Machine mart, a hacksaw, some patience and a lot of coffee  :happy2:
Have a look on Youtube for 'Project MK5' on Deutsche Auto Parts' channel.  They built a big turbo car and one of the episodes goes over making a DP, if you want some inspiration.
Offline Wolf Burger
« Reply #4 on: May 10, 2018, 09:43:17 pm »
Nortech Tubular Manifold and exhaust with an Owens Motorsport turbo.
Various Turbo options available....
Just go to Stattlers in Sheffield.
They do every option available and also can supply used CDL engines if you want to build a big power car.
Most tuners have followed this company when it comes to fitting big turbo kits.
Golf Mk6R 2011- Rising Blue- Manual-
Modifications-
E-Tuners 361 BHP - 350lbs
Revo Intake
Bilstein B16 & H&R ARB's
Team Dynamics 1.3
18Z Porsche BBK
RNS510 with Focal Speaker upgrade
MK6 Recaro Heated Buckets
Cruise Control
Highline Reverse Camera
Offline shaft69
« Reply #5 on: May 10, 2018, 11:17:14 pm »
There is TTE480 too.
Offline colesey
  • -Receive: 89
« Reply #6 on: May 11, 2018, 06:50:57 am »
Is worth keeping an eye on the TFSI parts for sale Facebook page and there is an APR GTX2867 Stage 3 kit listed for £3k
« Reply #7 on: May 11, 2018, 05:56:41 pm »
TTE480 doesn't make anywhere near 480 and CDLs break pistons easily with TTE420s and above.   Even that engine needs rods and pistons......unless you are sensible and tune it down and just enjoy a fatter torque curve, but everyone wants peak numbers.  Bye bye pistons  :sad1:
Offline tigamilla
« Reply #8 on: May 12, 2018, 04:05:33 pm »
Yes there is a full Nortech kit sold by TSR and AKS with a Garrett 3071R gen 2 turbo - i couldn't weld to save my life so relying on research and trying to get my head round what is sensible or not... yeah I think the screamer pipe would get tiring after one day of normal use. Thanks for the video suggestion - I'll take a look
Offline tigamilla
« Reply #9 on: May 12, 2018, 04:10:16 pm »
With this to really make the most of it you'd be forging anyway, so might as well plan to spend big and enjoy a proper big turbo, as has been pointed out, they make good power but apparently not the 480 hp quoted
