Author Topic: Canbus Gateway replacement - Issues  (Read 2621 times)
Offline DMackie
« on: May 07, 2018, 09:17:21 am »
Hello
Had a successful car modding weekend with my friend getting GPS aerial fitted, ramair intake and a newer version of the canbus gateway fitted (what a bitch of a job!)
Before replacing it my Parrot Asteroid Mini was working perfectly but since installing the new canbus the parrot system doesn't boot up sadly. First thoughts were that it wasn't plugged into the main hub, check that and it is. I haven't taken the stereo apart yet to check more as i only noticed it driving home after fitting everything.
Could the canbus gateway have changed anything to stop it booting or would it be a case that i knocked a plug loose?
DMackie
Re: Canbus Gateway replacement - Issues
« Reply #1 on: May 10, 2018, 04:20:32 pm »
You might need some features ticking in the replacement CAN Gateway module with VCDS, assuming no plugs have been knocked out.
Offline mjmallia
  • -Receive: 54
« Reply #2 on: May 11, 2018, 09:33:05 am »
I am guessing that you used VCDS to take screenshots of the original coding etc for your car before removing?
When you put the new one in, you need to then use VCDS again to recode it to match the original one you took out as there are many different settings that can create errors in the car.
Mike
South Coast
Offline DMackie
« Reply #3 on: May 11, 2018, 09:40:02 am »
No i just gave info to the guy on here who sells them precoded for you.
DMackie
Offline DMackie
« Reply #4 on: May 11, 2018, 09:58:33 am »
Would anyone know which options to select to get the parrot system to boot?
DMackie
Offline DMackie
« Reply #5 on: May 11, 2018, 01:31:05 pm »
Scanned the car and got a can gateway code
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 210608F1000825
   Coding: E9801F064000020001
   Shop #: WSC 00066 123 12345
   VCID: 3566ABB45CB2E8ECFB-8060
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 210937 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:10:30
Now i have a scan from before the canbus was installed. Should the coding be the same??
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A0706AE
   Coding: 3D0F0340070001
   Shop #: WSC 01279 785 00200
   VCID: 2A5C88C8850CB71197-807E
No fault code found.
Offline DMackie
« Reply #6 on: May 11, 2018, 03:25:49 pm »
I looks like number 37 navigation has been selected on the new canbus which wasnt selected on the old canbus and my MFD2 worked fine.
Do i uncheck that as the Radio module now has
56-Radio -- Status: Not registered 0011
DMackie
