Author Topic: Bit of help please all  (Read 2725 times)
Offline SpudGTI
  • -Given: 18
« on: May 07, 2018, 06:13:00 pm »
Hi all ive owned my golf mk5 AXX for nearly a year now and this has happened
New cam chain and tensioner
4 services engine 3 engine flushes whilst getting serviced
1 DSG service
New flywheel job
And now ive got this BAD tapping/banging comming from drivers rear of engine and low oil pressure light and oil can on display this only happens when im just crusing along but if i put me foot down it clears the code but after the first time of it alarming up it then starts rattling its head off and idel is struggaling like it wants to cut out but still banging/tapping it always boosts up hasnt lost power in anyway dosnet smoke
Its loud inside more than outside the car but its loud no matter what
Any idears guys ive spent so much on this GTI and blooming love the car but its getting expensive now im thinking possible turbo on the way out?? Any other thoughts guys?
Cheers all
Sent from my SM-G935F using Tapatalk
Offline SpudGTI
  • -Given: 18
Re: Bit of help please all
« Reply #1 on: May 07, 2018, 06:15:04 pm »
Sorry to dubble post but
The rattle is mainly when i stop the car and its ticking over at traffic lights ect but very recently it rattles when im still moving to pull up to stop
Offline doylebros
« Reply #2 on: May 07, 2018, 06:35:12 pm »
 I would be looking at your oil pick up pipe - this is worth a read below
http://www.mk5golfgti.co.uk/forum/index.php?topic=36395.0
Offline SpudGTI
  • -Given: 18
« Reply #3 on: May 07, 2018, 06:47:35 pm »
Will get my local vw man to give it a look when i see him to book it in just want to see what you guys think before i got to sit down and have a brain fart or 2 haha would that explain the tapping/banging?
Offline Sessions
« Reply #4 on: May 15, 2018, 11:43:09 pm »
Maybe the fuel pump follower/ tappet failing worth a check.
Offline GitFlog
« Reply #5 on: May 16, 2018, 12:13:33 am »
since you have already done the cam chain and tensioner i would defiantly check the oil pick up pipe (good call doylebros)
they have a habbit of getting stuck with loads of gunk
what mileage are you on??
2017 Vw Golf R Mk7.5
310ps
Lapiz Blue
Black Vienna Leather Interior
19" Pretoria Alloy Wheels
Dynamic Chassis Control
Offline SpudGTI
  • -Given: 18
« Reply #6 on: May 18, 2018, 08:21:35 pm »
Ive had the fuel pump bit done when cam chain was done the golf is on 90k now had it into the shop was the pick up pipe and rhe oil sensor all good now just sruck on the wiring for the boost sensor as the pulled the wires out of tje plug by accedent
Offline GitFlog
« Reply #7 on: May 18, 2018, 09:42:48 pm »
Is it jus the low oil pressure code you get?
did this happen long after the cam chain and tensioner was done?
This sounds like a bloody annoying problem i feel for you dude.
310ps
Lapiz Blue
Offline SpudGTI
  • -Given: 18
« Reply #8 on: May 19, 2018, 12:35:19 am »
Yeah kept getting it comming up on dash all good now tho was just somone in the past had the sump off and chucked a tone of silicon between sump and engine where it got old and spewed out it clogged the pick up but a good clean of sump and pick up pipe all good :D
But yeah a rite pain :(
Offline GitFlog
« Reply #9 on: May 19, 2018, 11:54:07 am »
What a plank they were, you have to be careful putting the sump back on with how much sealant you  use for that exact reason.
Glad its sorted :jumpmove:
310ps
Lapiz Blue
Offline SpudGTI
  • -Given: 18
« Reply #10 on: May 21, 2018, 09:08:03 pm »
Yeah haha atleast my garage is into vw's owner has a modifyed T4 and his son has a mk6 gti highly modifyed but his son has had a gpod cupple mk5s in the past so i should be in safe hands just a minor mishap on boost sensor but hey ho no ones perfect :)
Offline SpudGTI
  • -Given: 18
« Reply #11 on: May 21, 2018, 09:08:11 pm »
