Author Topic: Air Con works for about 2mins at a time?  (Read 3089 times)
Offline Clarky1994
« on: May 09, 2018, 12:53:58 pm »
Right so I've seen a few Air Con related problems on here recently (due to the hot weather no doubt) however, none seem to be the same as mine.
I put my Air Con on and it works for about 1-2 mins then it stops blowing, if I press the AC button off and then back on again it works fine again for another 1-2mins. So to keep the cabin cool I keep pressing the AC button off and on as I am driving along.
Any ideas because I am stumped? :thinking:
Cheers,
Clarky
Offline Gmac
  • -Given: 30
Re: Air Con works for about 2mins at a time?
« Reply #1 on: May 09, 2018, 07:44:50 pm »
I don’t have the answer Clarky, but mine is exactly the same, effing annoying, and really not sure why.  Hopefully someone has had this problem before and can point us in the right direction  :happy2:
Offline GitFlog
« Reply #2 on: May 09, 2018, 07:54:29 pm »
have you tried the flap calibrate/rest? worth a try
Also if you have a VCDS it would be worth having a check for codes and so on.
2017 Vw Golf R Mk7.5
310ps
Lapiz Blue
Black Vienna Leather Interior
19" Pretoria Alloy Wheels
Dynamic Chassis Control
Offline doylebros
« Reply #3 on: May 09, 2018, 08:16:40 pm »
There's plenty problems with the AC system and its component parts but since yours works,  then fails I would consider this area
https://m.youtube.com/watch?v=xMrU4XimsoI
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #4 on: May 10, 2018, 01:20:47 pm »
Sounds like you've got a mk5 TDI (diesel) golf and have fitted the mk6 climatronic panel?
If I'm right.... it's the ECU having a bug, which causes this.
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline Gmac
  • -Given: 30
« Reply #5 on: May 10, 2018, 06:18:16 pm »
I have a mk5 climate control panel, and I’ve got the exact same problems as the op
mkgolfnutters
« Reply #6 on: May 11, 2018, 09:12:14 am »
Hello there
I have a vw EoS 2.0 tsfi with the peoblem nothing when i scan with vcds.
would be nice to sort it out  now the nice weather is on it's way.
Offline Clarky1994
« Reply #7 on: May 11, 2018, 09:55:40 am »
Thanks for the suggestions, unfortunately I don't have a VCDS so I can't jump into that and have a look not that I would know what I'm looking at anyway haha so Ive had a go a the calibration and there is no change, and I have a mk5 GTI 2006 so would that still be an ECU problem?
Cheers,
Clarky
Offline Clarky1994
« Reply #8 on: May 11, 2018, 07:01:56 pm »
Okay so I know this won't help everyone however, I changed my mk6 climatronic pannel to an original mk5 one and the problem has gone, for me it seems the issue was the mk6 climatronic which is strange as I've never heard of people complaining about this issue?
Cheers,
Clarky
Offline 99hagued
« Reply #9 on: May 11, 2018, 09:36:47 pm »
Cheers,
Clarky
Did u do the wire swap with the mk6 panel?
Offline Clarky1994
« Reply #10 on: May 12, 2018, 10:23:34 am »
Cheers,
Clarky
No mate just plug and play, I thought that was the correct way of doing it?
Cheers,
Clarky
Offline 99hagued
« Reply #11 on: May 14, 2018, 11:26:48 pm »
Cheers,
Clarky
Cheers,
Clarky
You have to swap some wires about for the ac to work properly mate. Can’t  remember which ones because it was years ago I did mine but if you search this forum it’s here somewhere.
Offline Gmac
  • -Given: 30
« Reply #12 on: May 31, 2018, 07:37:20 am »
I’ve also got some info....
Found a thread on here where the guy swapped his aircon panel for a newer one and then the aircon did what the op has described. And basically there’s something on the newer panel that confuses the aircon and it does this shut off thingy. He swapped back to his original panel and everything was fine again.. I’ll try and find the post...here we go!
http://www.mk5golfgti.co.uk/forum/index.php/topic,53882.msg1108983.html#msg1108983
« Last Edit: May 31, 2018, 07:39:23 am by Gmac »
