December 16, 2025, 01:28:52 pm
All Things Mk5
Mk5 General Area
squealing shreaking noise
Topic: squealing shreaking noise (Read 1563 times)
gazzagti2018
May 14, 2018, 11:51:04 am »
Hi all
Newbie to the group and newbie mk5 GTI owner , took her on a run and notice a squealing type noise, not while breaking just general running ???
Ripstop
Always Involved
-Given: 1
-Receive: 11
Re: squealing shreaking noise
Reply #1 on:
May 15, 2018, 04:10:17 pm »
Fan belt? They squeal like crazy if they are getting a bit old and harden up. Aircon compressor could also be a culprit as the bearings on older models start to play up. Try it with aircon off and on and for the belt I also just put a little water on it as a test and run the car on a short trip.
Need a bit more info on where but I presumed engine bay and in the cabin?
Rip.
Stage 1 2007 Black Eddy #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic. The car is *always* work in progress fixing and upgrading things.
Octoparrot
Just look at my post count
-Given: 8
-Receive: 104
Reply #2 on:
May 15, 2018, 09:24:02 pm »
Could be a knackered pcv, do a search on YouTube for videos and see if the sounds are similar, also could be alternator bearings, tensioners, rollers etc. does it happen whilst stationary and at all engine speeds.
gazzagti2018
Reply #3 on:
May 17, 2018, 01:47:21 pm »
Thanks for the replies it happens after the engine is warmed up short runs, then after say 6 - 7 miles it starts, general running not braking or accelerating
All Things Mk5
Mk5 General Area
