Author Topic: Tailgate gas strut - force rating  (Read 2769 times)
Offline els904
« on: May 25, 2018, 10:42:29 am »
Could some kind person please have a look at their tailgate strut and tell me what the force rating is. I had mine replaced a while ago with non-OEM parts and it's very hard to close. They appear to be 550N and it would be useful to know what the original spec is.
Peter
Offline SpudGTI
  • -Given: 18
Re: Tailgate gas strut - force rating
« Reply #1 on: May 25, 2018, 11:09:25 am »
Hi Peter
Not sure what pressure they are but check the pic of my old ones ive fitted a popper kit so cant help with the ones fitted but will put a pic of my old OEM ones for you for if any help at all
Kris
Offline SpudGTI
  • -Given: 18
« Reply #2 on: May 25, 2018, 11:13:06 am »
Popper kit says 600n and arnt to bad to close stiff but ypu get used to it
OEM 535N?? Standard in pic
Tryed to get a pic of popper kit ones but writing to small for camera to pick up
Sent from my SM-G935F using Tapatalk
Offline els904
« Reply #3 on: May 25, 2018, 07:51:50 pm »
Thanks for this - 535 isn't much less than 550 and VW ones are £50 each! I'll just have to eat more shredded wheat!
Offline SpudGTI
  • -Given: 18
« Reply #4 on: May 25, 2018, 07:55:57 pm »
Hahaha i am 6ft 4 so probs helps
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #5 on: May 26, 2018, 06:03:47 pm »
I have the hatch pop kit. It has the 600N struts. I know it is only supposed to pop the hatch open...but when warm it opens the hatch completely. So, my thinking is "would a 600+N strut open when not warm" and "has anyone found a 600+N replacement?". I am unaware of which auto the pop kit's struts come off of...but think that an aftermarket replacement may be 600N plus given there's a 550N replacement for the oem 535N strut.
4ndy
« Reply #6 on: May 26, 2018, 06:26:12 pm »
SGS make specific pressure struts In shiny metal too https://www.sgs-engineering.com/gas-struts/stainless
Offline SpudGTI
  • -Given: 18
« Reply #7 on: May 26, 2018, 07:25:30 pm »
Mine is the the same dude next to all the time it just pops the seal dosent open all the way unless the a flying pig flys past in the sky since ive had them fitted must have opened all the way twice!!!!!! Even the mrs said blooming hell its opened haha
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8 on: May 26, 2018, 07:48:47 pm »
Right, mine only opens all of the way if it were sitting in the sun during the summer time.
Poppers are set correctly and I actually just replaced them due to broken internal springs. But if I could find say a 625N to 650N strut...maybe they'd open more often. I know these use a Cupra strut ball cap but do not know which struts are used. I think I can find out running a rearch for the oem part number. Closing isn't an issue as I can usually close the hatch by grabbing the inner grab with one hand and pull it downward.
Offline SpudGTI
  • -Given: 18
« Reply #9 on: May 26, 2018, 08:10:13 pm »
Mine dosent do it hot or cold so i must have weak struts or springs when you find some bigger power ones let me know please dude
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #10 on: May 27, 2018, 05:33:07 am »
I will...going to write down the oem number and search to hopefully find that one aftermarket, Fabi perhaps, makes a replacement strut with just a tad more lift.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11 on: May 27, 2018, 05:57:37 am »
My pn; 6Y0-827-550-C-01S is a Febi-Bilstein item no; 31652
All replacements for the above pn:, not limited to Febi, I found so far are 600N...but I will keep looking.
Specs are:
length: 440mm
stroke: 170mm
tube: 19mm
rod: 8mm
I found one for an Audi A6 pn: 4F9-827-552-D, having 650N but was 490mm length and stroke is 184mm. I will be relentless.  :drinking:
« Last Edit: May 27, 2018, 06:28:46 am by ROH ECHT »
