Author Topic: Major pull to the right after fitting SPORTLINES ..... NOW FIXED!!  (Read 8932 times)
Offline jon-tfsi
  • -Receive: 27
I had some Eibach sportlines fitted to the Leon yesterday and when I picked it up from the garage it was pulling quite strongly to the right. After a few seconds i noticed a light on the dashboard. Its the shape of a steering wheel and is the power steering warning light and is on YELLOW meaning a minor fault
Had the car on Vagcom last night and its coming up with only one fault code
00573 steering torque sensor (G269)
008 Implausible signal
This could be the power supply or the sensor at fault
I have had a good look at the sensor under the car and the wires look intact and undisturbed.
The worrying thing is the sensor is part of the steering rack and cant be replaced on its own.
The rack is £700+ just for the part
Has anyone else had issues like this after fitting suspension to Mk5 platform cars?
Any input would be appreciated before handing the car over to the dealers to have my pants down
« Last Edit: March 03, 2010, 06:06:41 pm by jon-tfsi »
GOLF R Mk7
Re: Help !! Major pull to the right after fitting SPORTLINES
« Reply #1 on: February 10, 2010, 01:39:56 pm »
they have not plugged the sensor back in so turn the steering wheel and stick your head in behind the wheels to see if its plugged
Offline jon-tfsi
  • -Receive: 27
« Reply #2 on: February 10, 2010, 02:30:59 pm »
This sensor is located on the steering rack itself.
Have just realised when on nearly full left lock it suddenly pulls left.
The only thing i can compare this to is when i bent a bottom ball joint on a nova.
I cant tell if its something mechanical causing the sensor or just the sensor itself?
GOLF R Mk7
« Reply #3 on: February 10, 2010, 02:32:44 pm »
Jeeze! Didn't the garage fully test the car before giving it you back!!?  :fighting:
Name and shame the garage.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #4 on: February 10, 2010, 02:37:39 pm »
as Robin says , what about alignment / checking?
Red ED35 5dr DSG
BLOG | BUILD
Offline QD MBE
  • -Receive: 102
« Reply #5 on: February 10, 2010, 02:42:08 pm »
Hmmmm.........   deja vu........
« Reply #6 on: February 10, 2010, 02:44:16 pm »
....Yeah, unfortunately some 'garages' just don't bother.
« Reply #7 on: February 10, 2010, 02:49:55 pm »
Take your car back to the garage,I assume it drove ok before hand
« Reply #8 on: February 10, 2010, 03:13:10 pm »
the steering wheel light come on when the speed sensor is unplugged when doing the spring to get the shock off so it will be that trust me
Offline djhorace
« Reply #9 on: February 10, 2010, 03:30:41 pm »
Not so good Jon. Hope it gets sorted out mate.
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #10 on: February 10, 2010, 03:48:21 pm »
Have you turned the steering wheel both ways lock to lock since youve had it back?
Try it then report back
Offline jon-tfsi
  • -Receive: 27
« Reply #11 on: February 10, 2010, 04:08:08 pm »
I got the springs fitted at a local garage one man band.
Hes ok but now that there is a problem he does not know what to do. I've just got back from taking the car down to him again.
Everything seems in order visually. He said he just swapped like for like. To be honest I'm blaming myself now for not taking the car somewhere with more facilities.
Yeah i have driven the car quite a bit. It generally pulls to the right, whether going left, straight on or right.
I did notice that at almost full left lock itdecided to pull to the left.
At 60mph it almost feels like there is nothing wrong with the car and the pull all but dissappears
Hey Matt is this speed sensor the ABS sensor as well by any chance? I have found a sensor located on the hub which I thought was the ABS sensor. Its connected up to the plug. If it was broken though or had failed it would be the same as if its not connected.
There are also sensors on the bottom arms, connected by small rods with a ball joint at either end. These look like they measure the travel of the bottom arms. Dont suppose they would throw a steering fault?
GOLF R Mk7
Offline jon-tfsi
  • -Receive: 27
« Reply #12 on: February 10, 2010, 04:11:31 pm »
Have also had it in to get the alignment setup.
They refused to do it but they did get it on the machine and its only out by a bit.
They reccommended i take it to SEAT and to be fixed and bring it back for alignment afterwards.
GOLF R Mk7
« Reply #13 on: February 10, 2010, 04:16:45 pm »
Did you run the car with the new wheels/tyres before you had the springs fitted?
« Reply #14 on: February 10, 2010, 04:19:59 pm »
bottom of the shocker u will see the plug just make sure its plugged in correctly as thats all he will have touched
