Author Topic: dash cam recommendations  (Read 972 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« on: May 31, 2018, 05:03:34 pm »
Hi, I'm hoping you'll have some recommendations for a dash cam, there are tons on Amazon but I don't trust their reviews.
Offline SpudGTI
  • -Given: 18
Re: dash cam recommendations
« Reply #1 on: May 31, 2018, 07:33:21 pm »
Next base from Halfords has always been good for me sent SD card off for accedent in last car helped ALOT and insurance said it was very good footage to use so a good brand and some insurance companys will reduce insurance cost if you have a gpod brand dash cam
Other than that get a gopro ;)
Sent from my SM-G935F using Tapatalk
Offline 99hagued
« Reply #2 on: May 31, 2018, 08:32:04 pm »
I have a thinkware dash cam and the pic quality is really good, not cheap tho
Offline GitFlog
« Reply #3 on: May 31, 2018, 08:39:46 pm »
I have a Transcend and the quality is really good.
Next base is another good brand but more expensive.
A good idea is to ring your car insurance and ask them what they would recommend as it might even put your cost down it did with my parents when they got one put on. It had to be fitted by VW tho.
2017 Vw Golf R Mk7.5
310ps
Lapiz Blue
Black Vienna Leather Interior
19" Pretoria Alloy Wheels
Dynamic Chassis Control
Offline SpudGTI
  • -Given: 18
« Reply #4 on: May 31, 2018, 08:48:50 pm »
Thinking about it my mate at work went to VW and got one fitted and set up for £250 but depends what your budget is
Offline GitFlog
« Reply #5 on: May 31, 2018, 09:12:43 pm »
Yeah its all about the monies, i got mine about 1 year ago and paid £200 as it came with all the gps and speed settings and i hardwired it in myself from an empty fuse locaton that was ignition live with a step down for 5v feed very easy.
My insurance didnt go down but i made sure the camera was good enough to catch number plates.
1 thing i would say dont get hung up on the fps to much you want a higher resolution than anything as 60fps is no good unless you have 1080p or more as dash cameras have a very wide field of view so this makes the number plates very small and use a lot less pixels. ideally something with 1080p or higher at 60/80 fps would be good anything higher is a bonus.
People get confused about the whole fps thing as they think just because they are recording at 60fps higher they should catch the number plate easier. But the truth is yes you might catch the number plate as you have 60 frames and not say 30 but you wont be able to read it due to the low resolution. You are better off with have 1 frame of the number plate you can read in the higher resolution than 10 that are fuzzy and useless.
Alot of people get out of paying for crashes and bumps they cause because the video is to blurry.
Just have a good look around and check quality and make sure you get one that has been proven to have the qualty you need. 99% of Ebay and Amazon ones are crap be careful.
Buy once Buy right
310ps
Lapiz Blue
