Author Topic: Car sat for a year no start  (Read 5119 times)
Offline Patters78
« on: May 31, 2018, 09:19:26 pm »
Hi guys
Can anyone help my poor 2006  Jetta TDI 140 BKD
So as the title car has sat for a year started and drove probably 2 times over that year just to move it,  anyway it was time to bring it back from the dead and start using her again so last month brought all service parts and a new battery.
Battery replaced filters changed didn’t do oil as work halted me getting on the road.
So forward on to this weekend just gone,  week off decided to finish it off get it running taxed/insured the egr was faulty so that was replaced the battery was dead so it was charged and put back in.
Started car started on second attempt and I took it for a 5 mile spin all good
Parked back at home repaired a faulty washer hose gave the plastic in the engine bay a clean with a cloth and wd40 then attempted to start it again nothing..
Noticed it only had 5 miles on clock so got some more diesel still don’t start
Following advice on another forum I have done the following
Fuel is being run through filter housing confirmed
Earth studs have been checked cleaned,  one snapped when checking so have extended wires and earthed to another point
Tried to jump start from another car resulted in smoke coming from large earth cable under air intake was corroded now cleaned
Have replaced all glow plugs
Battery has been taken off for the night to clear can-bus
Easy start used nothing
I’m now out of options and skill set if I’m honest
Haven’t got vcds located Tamworth if anyone has a good heart lol
Any suggestions
Gonna have to call a mobile mechanic as I cant move it
« Last Edit: May 31, 2018, 09:36:56 pm by Patters78 »
Offline GitFlog
Re: Car sat for a year no start
« Reply #1 on: May 31, 2018, 09:41:08 pm »
There is a list for members with vcds and so on check it out hopefully somone will be close and able to help.
Silly question when you did the service you did do the fuel filter ? Diesels go through them fast
2017 Vw Golf R Mk7.5
310ps
Lapiz Blue
Black Vienna Leather Interior
19" Pretoria Alloy Wheels
Dynamic Chassis Control
Offline Patters78
« Reply #2 on: May 31, 2018, 09:48:40 pm »
Yes changed checked today fully clean
Offline Patters78
« Reply #3 on: May 31, 2018, 09:48:54 pm »
I have also checked all fuses but can someone just look over these photos to make sure nothing is in the wrong place
https://ibb.co/eKqRay
https://ibb.co/grfg8J
Yes fuel filter done checked nice and clean
Offline GitFlog
« Reply #4 on: May 31, 2018, 10:06:23 pm »
it does sound like you could do with a vcds have you had a look at the list of members with them and chucked someone a message?
310ps
Lapiz Blue
Offline Patters78
« Reply #5 on: May 31, 2018, 10:31:26 pm »
Only member that is in Tamworth hasn’t been on for a year
Have posted asking for help
Don’t know why but I’m wondering if it’s the battery question if my battery was bad would jumping it bypass the battery or could it still cause issues?
( the reason I ask is my other car 2012 Passat recently had battery issues and I did try the Jetta battery on that and it did the same,  I put that down to not enough power ? Unsure )
Offline Patters78
« Reply #6 on: May 31, 2018, 10:40:22 pm »
Ah think I have made a mistake!
I ordered a 027 battery instead of the 096!!
Would this be the reason it’s not starting! How stupid!! Wow
Offline GitFlog
« Reply #7 on: May 31, 2018, 11:00:14 pm »
I think the only difference is the size of the casing, orientation and type of terminal posts. I cant see that being a problem.
If you have a multimeter you can check the battery to make sure its charged and being charged by your alternator.
When you try to start it does it try to turn over or is it completely dead?
310ps
Lapiz Blue
Offline Patters78
« Reply #8 on: May 31, 2018, 11:02:39 pm »
Turns over and would do until the battery gets flat
You sure it’s not the battery the 027 only has 480CCA while 096 has 640CCA
« Last Edit: May 31, 2018, 11:04:44 pm by Patters78 »
Offline GitFlog
« Reply #9 on: May 31, 2018, 11:09:39 pm »
So you turn the key and it turns over but dosent start yeah? You turned it over trying till the battery went flat?
Just had a check and the 027 batteries have a lower Ah and CCA that the 096 so this might be the problem i always thought it was the casting and so on.
Where did you get the battery from did they advise you on which one to get or did you choose yourself?
310ps
Lapiz Blue
Offline GitFlog
« Reply #10 on: May 31, 2018, 11:11:09 pm »
Take from GSF Car Parts forum post
Details from our system show:
027 - Length 241 mm, Width 175 mm, Height 190 mm, Battery Capacity 60 Ah, Cold-test Current, EN 540 A
096 -  Length 278 mm, Width 175 mm, Height 190 mm, Battery Capacity 77 Ah, Cold-test Current, EN 780 A,
But we also list the 065
065 -  Length 241 mm, Width 175 mm, Height 175 mm,  Battery Capacity 56 Ah, Cold-test Current, EN 480 A, Length 242 mm, Width 175 mm, Height 190 mm
310ps
Lapiz Blue
Offline GitFlog
« Reply #11 on: May 31, 2018, 11:16:48 pm »
Is it priming? The in tank fuel pumps seam to be a problem on these from what i can see and they dont throw up any codes. Would explain why its turning over and not starting.
I would defiantly put the right battery in tho just on the safe side
310ps
Lapiz Blue
Offline Patters78
« Reply #12 on: May 31, 2018, 11:17:54 pm »
Yes it’s been turned over till flat obviously not key in constant just over the day gone flat!
I have googled and most people are saying it should be the 096 for 1.9l tdi’s I’ve been a twit and ordered it myself not thinking!
Have reserved a Bosch s3 from eurocarparts collect in the morning
Offline Patters78
« Reply #13 on: May 31, 2018, 11:20:13 pm »
Yes it’s priming I think right
So took rubber hose off fuel rail after the filter placed them in coke bottle and turned it over both pushed through fuel the lower rail slightly at a lower rate tho?
Don’t know if that makes a difference
But yeah fuel is going through the filter into the rail
Offline Patters78
« Reply #14 on: May 31, 2018, 11:25:48 pm »
I do have a yellow engine light on but that is from the failed egr vavle tells me emissions garage and won’t go away till the flap opens again but it needs to be driven.
Don’t know if that is masking another fault that would throw up a yellow engine light tho
