Author Topic: DSG issue after service  (Read 1045 times)
Offline goku4ever
« on: June 13, 2018, 03:08:55 am »
I recently had my DSG oil and filter done at a local transmission garage. They used genuine vw oil and filter that I provided . I noticed since the service, changing the gear lever is a lot more stiff, especially putting into P. Also when going to S you could see the whole gear surround move. The car drives perfect and gear shifting is smooth.
I watch them do the whole process. Around 6 litres of oil was drained and same amount was pumped back from the bottom and then filter was replaced.
However, running the car to temp and releasing any excess was not done and they said it’s not necessary. This was a transmission garage so I took his word for it.
Any suggestions what could be causing it and what I should do. I just don’t want it to lead to something major, as I’ll be going for a stage2+ remap soon, all mods done.
