Author Topic: MK7 GTD Winter Wheels  (Read 3333 times)
Offline nads1_uk
« on: June 13, 2018, 12:39:12 pm »
Currently have a 64 plate GTD and looking for some cheap winter wheels.  My current wheels are 225/40/R18 (Rim is 7.5jx18 ET51).  I've got a couple of questions:
What is the smallest size wheel I'll get over the brakes?
What Rim size will I need?
What Tyre size would I need to keep the speedo reading right?
Apologies for all the questions.
Thanks in advance
Andy
Offline PatchySan
  • -Receive: 59
  • Gracie!
Re: MK7 GTD Winter Wheels
« Reply #1 on: June 13, 2018, 06:26:37 pm »
Assuming the MK7 GTD has stock brakes with 312mm discs the smallest wheel you can theoretically fit are 16" though it will be a squeeze. 17" would be a safer bet but what really matters is the clearance from the brakes and strut (offset) and the design of the spokes.
I generally use Willtheyfit to get a rough idea of how much poke you need to clear the strut and brakes from your existing setup, it helped me gauge an idea of what OEM wheel I need to fit over my Porsche Boxster brakes.
5x112 bolt patterned 16x6.5+ / 17x7+ wheels mainly but again offset is the key factor here. Use the calculator to see how much inwards/poke the new wheel setup will be.
205/55/16 or 225/45/17 are standard OEM tyre sizes and will be within <1% margin of error from the speedo.
Offline kam760
  • On the search for an edition 30.
  • My Ride: On the search for one...
« Reply #2 on: June 15, 2018, 11:26:21 pm »
Getting a set of steelies? What brand tyre are you looking at btw?
